Y harness batt packs = ?
Tower Hobbies
Logged in as Guest
  Printable Version
14MZ Battery and Charger
Seller:  Don Perry
Details:   $100.00   |  7/3/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Y harness batt packs = ?
Page: [1]
Login
Y harness batt packs = ? - 8/5/2002 10:40:00 PM
RabidDragon
Status: offline
If you took two 8.4 volt 1000 mamp battery packs and attached them to a Y harness to the ESC what would that give you?
8.4 volt 2000 mampS
16.8 volt 2000 mamps? (wrong I think)
seems that using this approach you could also get a higher amperage draw too for the larger motors while still using the small packs..... could use lithium packs with large motors
just wondering
       Post #: 1
Y harness batt packs = ? - 8/5/2002 11:08:37 PM
Red Scholefield
Status: offline
You will get the sum of the capacity of the individual packs.
_____________________________
Red S. AMA 951
R/C Battery Clinic
www.rcbatteryclinic.com
(in reply to RabidDragon)
       Post #: 2
Y harness batt packs = ? - 8/5/2002 11:50:45 PM
tmproff
Status: offline
Yep, you would be running in parallel, thus no change in voltage.
Si hoc legere scis nimium eruditionis habes....
       Post #: 3
Y harness batt packs = ? - 8/6/2002 10:47:05 PM
hilleyja
Status: offline
If in parallel add the amperage or capacity. If in series add the voltage.
Jim Hilley
AMA #671825
RCCA# 758
Twist 150 Brotherhood #14
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.297RCU1
