RE: Briggs and Stratton 34cc Fource?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
TurboHeader Muffler
Seller:  RC Specialties
Details:   $69.95   |  4/28/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: Briggs and Stratton 34cc Fource?
Page: <<   < prev  1 2 3 4 [5] 6   next >   >>
Login
RE: Briggs and Stratton 34cc Fource? - 4/18/2009 4:44 PM
Nosedragger
Score: 113
Last Login: 6/18/2013
Status: offline
Some guys cut the hook off the return spring to loosen it, its still needed to hold the cam down on the pin.Or use a high torque servo that has standard size case.Futaba 3305 has plenty of torque to over come the spring.
Nothing runs as good as the WY type of carbs on the four strokes, the WA and WT will run, but not as good.Throttle response will not be anywhere near as good as the WY with the WA or WT.
The butterfly type of carbs also require new manifold to supply pulse for pump and the large throttle bore needs to be transitioned into the port diameter over a distance long enough to not have the taper angle in the manifold bore too steep or fuel seperation will occur.I've seen WA 167s dribbling fuel out of carb at idle because of this.
Hide Signatures
(in reply to NorfolknGood)
       Post #: 101
RE: Briggs and Stratton 34cc Fource? - 4/18/2009 8:27 PM
jtisch
Score: 100
Status: offline
If you already have the WYK, I would cut the spring as mentioned elsewhere. It is not a super fun job but it can be done. I've done @ a half dozen of them.
J
_____________________________
WWI Aviation T-shirts
Hide Signatures
(in reply to Nosedragger)
       Post #: 102
RE: Briggs and Stratton 34cc Fource? - 4/19/2009 10:57 PM
NorfolknGood
Score: 100
Last Login: 7/22/2011
Status: offline
I removed the bent over end at the top which made very little difference so I then removed the other bend being careful to keep the ends smooth to help them slide. The spring still loads up and gives resistance so I found no benefit.
Hide Signatures
(in reply to jtisch)
       Post #: 103
RE: Briggs and Stratton 34cc Fource? - 4/20/2009 2:06 AM
JPMacG
Score: 123
Last Login: 6/19/2013
Status: offline
Briggs has very poor customer relations. I've had a very bad experience with them. Do yourself a favor and avoid them. Today's B&S is not the fine company they once were.
Hide Signatures
(in reply to Gismo)
       Post #: 104
RE: Briggs and Stratton 34cc Fource? - 4/20/2009 2:12 AM
Nosedragger
Score: 113
Status: offline
something is wrong, unhooking it lets off a lot of tension.
Hide Signatures
       Post #: 105
RE: Briggs and Stratton 34cc Fource? - 4/20/2009 7:33 PM
jtisch
Score: 100
Status: offline
The cut off ends are probably catching. I put a slight bend inwards at the ends. I also cut off a loop or two, there is still plenty of spring.
Hide Signatures
       Post #: 106
RE: Briggs and Stratton 34cc Fource? - 4/20/2009 8:35 PM
NorfolknGood
Score: 100
Status: offline
I experimented with the original carb and naffed it up by cutting off a coil, for some reason it jammed it up! Stil gotta get a prop adapter made, I have a mate with a lathe but I have no materials other than a 16" length of 3 3/4" ali, a right sod to cut and a lot of material to remove to!. I don't like the idea of a basic shaft with a hole tapped the size of the crankshaft thread and attaching with thread lock. I would rather machine out the centre where the shaft nut goes to a circle, machine off the face and 2 original tapped holes which the clutch was attached to then fit a Zenoah type prop adapter not using the crank thread at all. The machined central hole with keep things central and the 2 8mm tapped holes will hold the adapter on if you see what I mean.
I'm sure I can overcome the throttle issue with a fiddle, just been attending to other things for the last few days and I also have a little 22cc 2 stroke I'm converting to
Hide Signatures
       Post #: 107
RE: Briggs and Stratton 34cc Fource? - 4/21/2009 7:48 PM
motorhd
Score: 100
Status: offline
I have found that on the WYK, that it is best to leave the spring complete. Just lift it out of its notch and unload it to almost closed. Than carefully cut a new notch. Try not to disturb the area where the seal is.
motorhd
Hide Signatures
       Post #: 108
RE: Briggs and Stratton 34cc Fource? - 4/23/2009 12:17 PM
NorfolknGood
Score: 100
Status: offline
TBH I still don't understand why a normal Walbro cannot be sued, I have spoken to my local garden machinery place and they say they all work basically the same. I have also picked up a couple of small 2 strokes that use the WYK type carbs so if they will work on a 2 stroke surely a normal Walbro will work on a 4 stroke? Much easier to get hold of a Normal carb which has H & L jet adjustment.
Hide Signatures
(in reply to motorhd)
       Post #: 109
RE: Briggs and Stratton 34cc Fource? - 4/23/2009 3:51 PM
The Raven
Score: 105
Status: offline
I plan on trying some various Walbro carbs on my 34 once I get the conversion finished. A friend of mine has already converted his (yet to fly though) and it hand starts beautifully. Only downside is the low revs. I'm certain a revised carb and intake will make things more compact and add a few RPM.
Can anyone advise as to a safe upper rpm limit for these engines?
Hide Signatures
       Post #: 110
RE: Briggs and Stratton 34cc Fource? - 4/23/2009 4:08 PM
NorfolknGood
Score: 100
Status: offline
quote:
ORIGINAL: The Raven
I'm sure I read somewhere that used in boats they are revving to about 10,000 but don't quote me I have tried a couple of Walbros but could not get them to run right but I suspect I have an issue with the carb I tried which was a 10.5mm bore and has the H & L needles, I could not get it to tick over, perhaps a velocity stack may help the throttling but not sure about tick over.
Hide Signatures
(in reply to The Raven)
       Post #: 111
RE: Briggs and Stratton 34cc Fource? - 4/23/2009 4:42 PM
jaav
Score: 106
Last Login: 6/6/2013
Status: offline
The Briggs engine...
I work for a briggs dealer and have had too many failures. The plastic cam drive gear on the crank is very weak, had them fail on the 1st tank, the best part is the parts!! GOOD LUCK...
Right after a spectacular crash, the pilot yelled out ''Channel 35 clear!
Hide Signatures
       Post #: 112
RE: Briggs and Stratton 34cc Fource? - 4/23/2009 4:47 PM
NorfolknGood
Score: 100
Status: offline
quote:
ORIGINAL: jaav
Sorry I hijacked the thread, I was talking about the Honda GX31 conversion.
Hide Signatures
(in reply to jaav)
       Post #: 113
RE: Briggs and Stratton 34cc Fource? - 4/23/2009 4:59 PM
Nosedragger
Score: 113
Status: offline
quote:
ORIGINAL: NorfolknGood
quote:
ORIGINAL: The Raven
The boat guys are running Hondas with a full support crank, Honda has the engine rated for 10,000 from the factory. With the cantilever crank the B&S shouldn't run over 8500.check B&S recommendations.
Hide Signatures
       Post #: 114
RE: Briggs and Stratton 34cc Fource? - 4/23/2009 5:10 PM
jaav
Score: 106
Status: offline
The honda gx 25 series, now thats a better choice, havent seen them blow except from abuse...
Have a SPAD bipe in the works that will run the 35..
Hide Signatures
       Post #: 115
RE: Briggs and Stratton 34cc Fource? - 4/23/2009 5:58 PM
NorfolknGood
Score: 100
Status: offline
So what wingspan and weight/type aircraft are you guys using your BS, Honda etc 4 strokers in? Ther has been debate on another forum that says they don't have enough hp to be of any use, I have been defending the Honda GT31 as it appears to be the best Honda weight for hp IMO. Any of you guys got pictures of your 4 strokers in your airframes?
Hide Signatures
(in reply to jaav)
       Post #: 116
RE: Briggs and Stratton 34cc Fource? - 4/24/2009 1:12 AM
The Raven
Score: 105
Status: offline
quote:
ORIGINAL: jaav
Is there a replacement alloy drive gear or, does anyone have the know-how to produce better gear drives? If a better part can be used I'd rather put it into the engine before it flies.
Hide Signatures
(in reply to jaav)
       Post #: 117
RE: Briggs and Stratton 34cc Fource? - 7/10/2009 2:01 AM
stevelesl
Score: 105
Last Login: 6/12/2013
Status: offline
If anyone is still looking at this thread, here is a couple of pics of my recently completed plane with Honda GX 25...
I had the same issues with the carb return spring, every time I tried cutting the hook off, I ended up with a spring that wouldnt coil tight enough to fit in the space above the barrel. Did any of you guys remove the barrel to cut the spring, if so, how did you do this ?
You may see the added plate ofer the carb, this was to hold a spring on top of the barrel.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 118
RE: Briggs and Stratton 34cc Fource? - 7/10/2009 2:06 AM
NorfolknGood
Score: 100
Status: offline
Certainly am watching and with much interest. Nice to see the Honda in an airframe, how does it fly? What's the noise like with just a header pipe? I have changed my carb to a normal type Walbro and it's transformed it, I just had to drill the manifold to fit a pipe to the carb for the pump and it works a treat. I forgot to mention mine is the GX31.
Hide Signatures
(in reply to stevelesl)
       Post #: 119
RE: Briggs and Stratton 34cc Fource? - 7/10/2009 2:09 AM
stevelesl
Score: 105
Status: offline
I is pretty low on power but flies the 14lb model ok.
noise is low and sounds great, idles at @ 1300rpm with a "put put" sound !!
Which carb did you use ?, the carb on it is a walbro but the return spring issue is a real pain in the a**.
Hide Signatures
       Post #: 120
RE: Briggs and Stratton 34cc Fource? - 7/10/2009 2:15 AM
NorfolknGood
Score: 100
Status: offline
quote:
ORIGINAL: stevelesl
noise is low and sounds great, idles at @ 1300rpm with a ''put put'' sound !!
That sounds promising, I intend to put my 31 in a 1/4 scale SE5a. I cant tell you which carb I used, it came from my local garden machinery shop off a scrap strimmer, it's at my mates right now having the prop driver made so I cant just nip out and get numbers for you. I'm hoping to throw a 18 x 6 wood prop at about 7,000rpm with any luck. I will report as soon as I have run it with the newly made driver.
Hide Signatures
       Post #: 121
RE: Briggs and Stratton 34cc Fource? - 7/10/2009 2:21 AM
stevelesl
Score: 105
Status: offline
My 25 pulls a 16 x 8 at @ 7k, tried an 18 x 6 but it goes down to about 6.6k and doesnt appear to pull as well.
I heard the 35cc will pull an 18 x 8 to 7k with no problems........
Hide Signatures
       Post #: 122
RE: Briggs and Stratton 34cc Fource? - 7/13/2009 11:29 PM
Prop Nut
Score: 100
Last Login: 5/12/2012
Status: offline
If you look far enough back you will see that I have a couple of the 34cc B&S engines and one 40cc B&S engine. I used a 34cc on my Fokker DVII (for about two years) and it flew fine...a little underpowered but if you have plenty of space to climb out it is fine...great power once it is run out in the air for loops, etc. The DVII is 22lbs (1/4 scale). I bumped that plane up to 40cc B&S (Thanks Jtisch!) and it has excellent power and flight now, pulles right off the ground and up into the air. The 40cc is no heavier than is the 34cc. I use the 34cc on a Fokker DVIII (BalsaUSA) and another on my 1/4 scale Bud Nosen Aeronca champ. The 34cc flies both planes excellent. The best thing is, you can mount them inverted! A buddy has the Honda 31cc on a BalsaUSA Fokker DR1 and it is an amazing flier. I would post flight videos but the host that I was using disappeared (Putfile.com)
Scope? Listerine? Or Prop Wash?
Hide Signatures
       Post #: 123
RE: Briggs and Stratton 34cc Fource? - 7/14/2009 12:53 AM
Nosedragger
Score: 113
Status: offline
Putfile did itself in,they went offline a couple months ago. Why not reload your vids to You Tube?
Hide Signatures
(in reply to Prop Nut)
       Post #: 124
RE: Briggs and Stratton 34cc Fource? - 7/14/2009 12:55 AM
Prop Nut
Score: 100
Status: offline
I would...if I knew where I saved them!!!
Saved them so good I can't find them now, lol
Hide Signatures
       Post #: 125
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> RE: Briggs and Stratton 34cc Fource?
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.344RCU1
