throttle problem....maybe you know....
Tower Hobbies
Logged in as Guest
  Printable Version
HPI Racing Baja 5B - RTR
Seller:  lisa2803
Details:   $799.99   |  11/22/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> CEN Racing >> throttle problem....maybe you know....
Page: [1]
Login
throttle problem....maybe you know.... - 9/23/2004 11:28:23 PM
ndeepoffroad
Status: offline
On my CEN MT2, lately I have had a problem w/ the throttle being finicky. When I get it started, I try to give it gas and the throttle just hesitates and jerks back and forth. It will never reach full throttle and when it does it is in short bursts. It is like it is twitching. I have replaced the batteries in the truck and controller, and have a fail safe on the truck. I have tried it w/ and w/out the failsafe w/ no change. I changed out the steering servo, but that shouldn't affect the throttle. I don't know what is wrong, since the truck is fairly new.
Any help or ideas will be GREATLY appreciated.
Branndon
_____________________________
Mostly a Real Truck Guy, But Damn R/C's Are FUN!
       Post #: 1
RE: throttle problem....maybe you know.... - 9/24/2004 5:00:52 PM
Status: offline
Brandon,
On the throttle arm for the carburater there are two holes in which you can mount the linkage to. If you put the linkage into the lower hole, you will get more throw... which will make it hit full throttle easier. After doing so you will have to re-set the endpoint adjustments on your radio however. Also, make sure that your radio is set to the 7:3 ratio, this works much better for gas applications. If you have any more questions you can email customerservice@cenracing.com or give us a call, and one of our technicians will be happy to help you out. Thanks Brandon.
Regards,
CEN RACING
Best Regards
CEN Racing - www.cenracing.com
(in reply to ndeepoffroad)
       Post #: 2
RE: throttle problem....maybe you know.... - 9/24/2004 6:29:00 PM
ndeepoffroad
Status: offline
no, it isn't the mechanical setup, it is something electronic i think, because the servo is going nuts.
(in reply to CEN Racing)
       Post #: 3
RE: throttle problem....maybe you know.... - 9/26/2004 12:27:32 AM
tamiyakid08
Status: offline
are you running on am or fm? if am you might have interference. if FM, i have no clue
       Post #: 4
RE: throttle problem....maybe you know.... - 9/27/2004 5:53:46 PM
Status: offline
Brandon,
I recommend that you get into contact with one of our technicians, if you cannot figure the problem out. Thanks.
Regards,
CEN RACING
Best Regards
(in reply to tamiyakid08)
       Post #: 5
RE: throttle problem....maybe you know.... - 9/27/2004 6:14:21 PM
Hands
Status: offline
Check your crystals, make sure they are presses all the way in and while your at it double check the plugs going into the reciever.
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.500RCU3
