RE: Question About a Rc model
Tower Hobbies
Logged in as Guest
  Printable Version
HPI SAVAGE 14MM HEX HUB WHEEL EXTENSIONS - RTR
Seller:  wheelextensions
Details:   $22.00   |  10/23/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> RE: Question About a Rc model
Page: <<   < prev  1 2 [3]
Login
RE: Question About a Rc model - 10/4/2004 9:20:30 PM
Nitro Rustler Racer
Status: offline
i got a cheap way for seeing if your engine is over heating. when you warmed your truck up spit a bit onto the head of the engine where the glow plug is if it starts to sizzle right away your to hot if it sits there for like 3 secs and starts to sizzle your good
_____________________________
Nitro Rustler: OS.18 THS pipe RPM goodies Futaba Radio
(in reply to Bigup MT2)
       Post #: 51
RE: Question About a Rc model - 10/4/2004 9:25:39 PM
Nhill527
Status: offline
i got my truck in today but one of the servos are broke. anyone know a way to fix it ? it's broke at the top where top bols into the sfat for the servo.. i cant really explain it so i hope you all know what im talkin about
Tiffany
(in reply to Nitro Rustler Racer)
       Post #: 52
RE: Question About a Rc model - 10/5/2004 3:00:02 AM
Nhill527
Status: offline
i got the servo fixed. it cranks, runs alittle but will die. it runs ok when you give it trottle and drive it around but when you let it idel it will shut off. anyone know ow to fix this ? i've looked the manual over but it wont say where the factory settings are at so i can redo it all over..
Tiffany
(in reply to Nhill527)
       Post #: 53
RE: Question About a Rc model - 10/5/2004 3:07:37 AM
oatmealman
Status: offline
try adjusting the lsn(low speed needle)
       Post #: 54
RE: Question About a Rc model - 10/5/2004 3:18:56 AM
Nhill527
Status: offline
i tried.. im lost on which way to go.. i really need the factory setting for the lpn so i can set it to factory settings and work with it from there
Tiffany
(in reply to oatmealman)
       Post #: 55
RE: Question About a Rc model - 10/6/2004 10:47:20 PM
dalosiman
Status: offline
Sounds like your ide speed screw needs to be adjusted, To fix this start the motor and keep it at idle and if it wont run then turn the idle speed adjustment screw in at 1 hour increments untill it idles steady. If the motor is fresh and stops as soon as you pull the glow ignitor off then you may need a new glow plug, new motors are known for popping a plug or two! I made another post recently with the detailed instructions on how to set the idle speed screw on a carb. Heres the link to the post. http://www.rcuniverse.com/forum/Throttle_Linkage/m_2219468/tm.htm
Hope this helps! Jon
Horsepower = How fast you hit the wall!
Torque = How much of the wall you take with you when you hit it! =)
       Post #: 56
RE: Question About a Rc model - 10/9/2004 4:53:29 AM
Nhill527
Status: offline
I'm now having trouble with it over heating. seems like no matter what settings i try it wont quit over heating...
Tiffany
(in reply to dalosiman)
       Post #: 57
RE: Question About a Rc model - 10/9/2004 2:34:51 PM
dalosiman
Status: offline
If you leaned it out or overheated it too much you may have toasted the piston and sleeve. I did this with a Mach .15 on a XXX NT once and no matter what I did it wouldnt stop over heating. I bought a new piston and sleeve and put it in and broek it in and from then on it was fine. I know your strapped for funds but I would again reccomend getting a temp gun before anything else and that way you can closely monitor the temps while running the motor so you can adjust accordingly. I bought my Duratrax temp gun for 25 bucks off of ebay and it is just as accurate as the Ray-Tech costing 3 times as much that the guys at our track use.
       Post #: 58
RE: Question About a Rc model - 10/9/2004 11:49:46 PM
Nhill527
Status: offline
truck still runs ok. it didnt run hot long. i stop it alot and check it for steam coming up and when it has steam coming from it i'll shut it down.. i dont think its leaned out to much because it has smoke coming from it when i give it trottle
Tiffany
       Post #: 59
RE: Question About a Rc model - 10/11/2004 1:12:31 AM
Nitro Rustler Racer
Status: offline
even if your truck is leaned out you will still have some smoke coming. try to richen it a bit
       Post #: 60
RE: Question About a Rc model - 10/12/2004 8:58:56 AM
Nhill527
Status: offline
seems like all i am doin is having trouble with my truck now.. servos is going nuts. my steering isnt working right and my trottle servo goes to open trottle and they like jump when you dont give it any input...
Tiffany
       Post #: 61
RE: Question About a Rc model - 10/13/2004 2:46:54 AM
Nhill527
Status: offline
nvm.. got it fixed lol the batterys was weak, replaced them and now they work.
Tiffany
       Post #: 62
Jump to:
