Question About a Rc model
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> Question About a Rc model
Page: [1] 2 3   next >   >>
Login
Question About a Rc model - 9/24/2004 12:01:12 PM
Nhill527
Status: offline
Does Anyone Know If The SmarTech rc's off ebay are anygood ? here are some of the specs on one rc..
SOLID AND STURDY 2MM ALUMINUM CHASSIS
DISC BRAKE SYSTEM
ASSEMBLED CHASSIS
ORIGINAL MUFFLER AND AIR FILTER
FOUR WHEEL DRIVE SYSTEM WITH SHAFT DRIVE
OIL FILLED SHOCK ABSORBERS
DIFFERENTIAL WITH BUILT-IN FRONT AND REAR BEVEL GEARS
POWERFUL ENGINE EQUIPPED WITH SLIDE CARBURETOR AND PULL-STARTER
DOUBLE WISHBONE SUSPENSION ARMS WITH ADJUSTABLE WIDTH
ALUMINUM UPPER PLATE AND CHASSIS
HIGH IMPACT WHEELS
FRONT AND REAR BEARING DIFFERENTIALS
DISC-SHAPED BRAKE SYSTEM
FRONT UNIVERSAL JOINT SHAFT
80 CC FUEL PRESSURE TANK WITH PRIMER PUMP
NO-FLEX CHASSIS DESIGN FOR BETTER PERFORMANCE
HIGH TRACTION TIRES
SERVO SAVER LINKAGE SYSTEM
or if anyone justs wants to look at it here is the webling..
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=19168&item=5921851450&rd=1
Thanks For Looking And For You're Time
_____________________________
Tiffany
       Post #: 1
RE: Question About a Rc model - 9/24/2004 4:21:31 PM
redheat8
Status: offline
No sounds like crap to me save your money an get something that'll last, RED
2- Tmaxxes, RC10GT, T3, B4, TC3 Time to rock
(in reply to Nhill527)
       Post #: 2
RE: Question About a Rc model - 9/24/2004 4:26:17 PM
Nhill527
Status: offline
k.. thanks.. does anyone know where i can get a good truck ? i dont have a big budget.. just $200 is all i can afford right now, i want one thats ready to go but the smartech was the only ones i found that was cheap enough to buy with $200
Tiffany
(in reply to redheat8)
       Post #: 3
RE: Question About a Rc model - 9/24/2004 4:30:23 PM
chAz15
Status: offline
I'd wait and save another 50 or 100 bucks and get the RC10GT Plus RTR.
That's a kick A$$ truck for the money out of the box...
Fuel glow plugs battery for the grip and your good to go...
Go check out some of the swap / buy forums at hobbytalk.com you might find something there ready to go in your price range...Some of those guys are looking to get something new so they will give you a whole bunch of extra's (parts tires etc) with the car. Really good deals.
L8R
chAz
       Post #: 4
RE: Question About a Rc model - 9/24/2004 4:32:11 PM
Nhill527
Status: offline
k.. thanks
Tiffany
(in reply to chAz15)
       Post #: 5
RE: Question About a Rc model - 9/24/2004 4:36:08 PM
redheat8
Status: offline
Ditto on what Chaz said, RED
       Post #: 6
RE: Question About a Rc model - 9/24/2004 4:59:02 PM
chAz15
Status: offline
Go to hobbytalk, Staticsag post 8-19-04 under Off Road Swap has a FS: RC10GT Factory Team.
Lists everything for 215 and a price drop. So I think he would even go under your price range since he's had it up there a while.
Hooked up!
L8R
chAz
       Post #: 7
RE: Question About a Rc model - 9/24/2004 5:15:45 PM
Nhill527
Status: offline
is that a good truck ?
Tiffany
       Post #: 8
RE: Question About a Rc model - 9/24/2004 5:48:27 PM
chAz15
Status: offline
The RTR PLUS is supposed to be Rockin' out of the box...
RC universe has AD's for Factory Team and RTR as well...check around...
L8Rs
chAz
       Post #: 9
RE: Question About a Rc model - 9/24/2004 10:58:43 PM
amsterdamn
Status: offline
It's not crap like Red says. That is an uneducated statement. Besides, asking whether or not a vehicle is any good is no use in this forum. All you will get in reply is people saying you should get what they have. Just look at all the "what truck is the best" posts. It is ridiculous. The truth is you can get a very good deal on a Smartech vehicle because you get a lot for the money and spare parts are cheap. The bad part is, however, Smartech says they are "closing [their] doors" (going out of business). They will supply spare parts for as long as possible, but after that you're on your own. As said, spare parts are cheap, but unfortunately not necessarily readily available. Chances are you won't find what you are looking for at your local hobby store. So, Smartech vehicles are not crap, but in the long run you would be better off chosing a much more popular vehicle. If you are looking for a stadium truck, the ST-15 is a great deal for the money, spare parts are inexpensive, and it has decent options. For a few bucks more you will get more for you money with an Evader and their options are a little bit better. The RC10GT costs more, but is a great truck with many options. The Losi trucks are better for racing than bashing and is on the upper end of the ST pricing scale. Regardless of what you choose you will continuously spend money on it. That is, if you want to keep running it. Because, you will break the thing from time to time and you must have support equipment, fuel, glow plugs, tools, etc.
       Post #: 10
RE: Question About a Rc model - 9/24/2004 11:15:05 PM
Nhill527
Status: offline
ok.. i found this one, how r these trucks??? DURATRAX OVERDRIVE ST NITRO 4WD STADIUM TRUCK RC
Tiffany
(in reply to amsterdamn)
       Post #: 11
RE: Question About a Rc model - 9/24/2004 11:19:58 PM
amsterdamn
Status: offline
quote:
ORIGINAL: Nhill527
That truck has been discontinued. Spare parts will be harder to come by as time goes on.
       Post #: 12
RE: Question About a Rc model - 9/24/2004 11:25:16 PM
oatmealman
Status: offline
get the evader st
       Post #: 13
RE: Question About a Rc model - 9/24/2004 11:42:03 PM
Nhill527
Status: offline
what about this one..
HPI nitro rush evo.
included is:
new t-15 with one tank of fuel thru it. I started break in but havent finished it.
two prolind dirt works back tires 60% tread left
stock front soft ribs like new
pro line ribed tires on truck and proline square spikes on rear
two extra wheels with losi pin tires not glued to wheel. tires were glued but came off.
roto start setup
silver ford body great condition
stock red body good condition
extra stock trany gears
stock dog bones
Mip cvd's installed in rear
airtronics blazer radio
Tiffany
(in reply to oatmealman)
       Post #: 14
RE: Question About a Rc model - 9/24/2004 11:57:22 PM
oatmealman
Status: offline
sounds good
