jmir
NC, USA Status: offline
I looked at the Art-Tech page and could not find the motor you mentioned in your message. Nevertheless, if it's a stick mount, I think you could still use the motor housing that comes with the stock Cessna. I would just turn it around (bottom of the housing would then be the top), drill holes on the housing and attach the stick mount to it. You might have to shorten the housing, depending of what kind of motor you are using, how long the shaft is, etc. You can also make one out of light, plywood. There are several samples of motor mounting in these forums if you search for them. I think Glen Clovey has some using plastic pipe, if I remember correctly. I'll try to find these for you. By the way, I'm still using the stock motor that comes with the Cessna. It's not the original, but a replacement. It has lots of power and I'm only using a 2S, 7.4V li-po with it. Tried a 11.1V li-po, but was afraid the wings might fold with all that extra power. Also, the motor may not last as long. I have not actually measured the speed, but it has to be close to 50 mph.
_____________________________
Not raining? Not too windy? Guess what I''m doing!
