RE: Art-Tech 3Ch Cessna 182 RC Radio Control Plane
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Foamies! - RC Electric Foam Aircraft >> RE: Art-Tech 3Ch Cessna 182 RC Radio Control Plane
Page: <<   < prev  115 116 117 118 119 120 121 122 [123] 124   next >   >>
Login
RE: Art-Tech... - 8/4/2008 10:29:02 AM
RC_Kiwi
Status: offline
Yeah I'm thinking of doing the dual aileron servo mod too.
(in reply to ash99)
       Post #: 3051
RE: Art-Tec... - 8/5/2008 9:36:29 AM
ash99
Status: offline
I assume that the best place to mount the servos would be on the wing directly in front of the aileron control horn so as to keep the control rods as short as possible. That would leave the current servo aileron free to control flaps instead of using flaperons. The main problem I can see is that the servos would interrupt the free flow of air under the wings but I don't know if this would matter much.
(in reply to RC_Kiwi)
       Post #: 3052
RE: Art-Tec... - 8/5/2008 10:17:42 AM
RC_Kiwi
Status: offline
I'd use micro servos. How do you do the flap mod anyway? could someone post pics?
(in reply to ash99)
       Post #: 3053
RE: Art-Tec... - 8/5/2008 11:45:00 AM
Gronsta
Status: offline
If you use small enough servos you can imbed them in the wing. I'll go and take some pics of mine now.
_____________________________
The hardest thing about learning to fly is the ground!
       Post #: 3054
RE: Art-Tec... - 8/5/2008 12:04:19 PM
Gronsta
Status: offline
I wasnt thinking straight when I fitted the servos, I'd already mounted the horns trying to use the same setup as the ailerons (which I couldnt get to work properly ) so I dug out the reliefs with a sharp knife till the servos sat flush then I made a shallow channel for the servo leads with a soldering iron. I need to sort out some better hinges, the tape I used (copying the ailerons) isnt working as good as I hoped.
Hope this helps,
Dave
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to Gronsta)
       Post #: 3055
RE: Art-Tec... - 8/5/2008 12:08:57 PM
Gronsta
Status: offline
Forgot to say, the servos I used are the same arttech servos used for the elevator and rudder
       Post #: 3056
RE: Art-Tec... - 8/5/2008 2:41:54 PM
The_Mongrel
Status: offline
I mounted the in the wing right inline with the horn. I used HXT900s and they roll her VERY quickly. The air under the wing does not really matter as the it is the air OVER the wing that does all the lift. Obviously anything hanging below the wing will create drag, but when your Cessna is pulling 25A drag is not an issue!
If you upgrade the power plant you might want to think on reinforcing the wing with a carbon spar. I have - is dead easy and will stop your bird from snapping a wing in a high banked turn.
If you want some pics, just let me know.
Cheers
-J
Crashing is such sweet sorrow!
       Post #: 3057
RE: Art-Tec... - 8/5/2008 7:28:43 PM
tam popo
Status: offline
Gentlemen (and I use this term lighltly!!!!) - just a tip when buying servos. Servos are all the same in the 5grm and 9grm range - WRONG!!!! yes. the gear wheels are all white, but what are they all made of, d'ya know?? Its plastic, the stuff that keeps you're trousers up or may even down!!!! But there are servos the same price that are 50% better (not foolproof!!) becuase the gear wheels are ceramic or 'export only' - twice as hard etc etc. just do a search oI-net or ask you're LHS owner etc. It will save you pounds/$/yen etc.
And no - I will not buy a Cessna 'cos my wife's cupboard is tooo small......
My servos: HXT, DYS and jut search and ask....its your money and plane
What do i fly when i'm now retiered at 53... 20 planes from a Zagi, new MPX EZCub, 3 EZ*, Cub, Formosa, my fave the SlowStick, and quite a few more etc....and Strykrs..
What does Mongrel fly? A ballistic Cessna, an amphibean, a 3D Profile, and 50 or more beauts of planes....lucky Bar Steward......
Born to fly and loose my postings on RCU......
(in reply to The_Mongrel)
       Post #: 3058
RE: Art-Tec... - 8/6/2008 1:07:33 AM
The_Mongrel
Status: offline
Hey Tam... You forgot the P38, P51, Extra, F35, etc etc etc etc etc etc!!!
(in reply to tam popo)
       Post #: 3059
RE: Art-Tec... - 8/7/2008 12:19:25 PM
Gronsta
Status: offline
By mistake I orderd 2 2409-18's. With a 9x4.5 and a 8x4 the Cessna did not want to gain air, it just kept pointing straight up then stall turning into the ground. 2409-12 now fitted but does anybody know of a nice twin prop model I could fit these to so they dont go to waste? something that would fly[:@)
Am almost finished rebuilding a mates .11 Fuji, wonder how that would go
       Post #: 3060
RE: Art-Tec... - 8/7/2008 4:47:16 PM
ash99
Status: offline
Hi All,
Thanks for the info, I have already upgraded the moter and fitted carbon fibre rods to the wings and elevator. I have since hit the deck hard a couple of times and now instead on the wings breaking the fuselage simply crumples up.
       Post #: 3061
RE: Art-Tec... - 8/8/2008 12:33:15 AM
The_Mongrel
Status: offline
quote:
ORIGINAL: ash99
Hi All,
Yep!! That will happen when foam meets the ground at a high rate of speed!!
The best way to prevent that is don't crash!
(in reply to ash99)
       Post #: 3062
RE: Art-Tec... - 8/8/2008 9:26:18 AM
ash99
Status: offline
That may be ok for you "experts" but for us mere mortals it's easier said than done. I think I must have one of the few Epoxy Cessnas flying. It does has bits of foam here and there, but not much!
       Post #: 3063
RE: Art-Tec... - 8/8/2008 12:04:42 PM
Gronsta
Status: offline
Hey Ash, you do reach a point where you have put so much epoxy into it that the 2408 is working to get it airborne . I thought I would be lucky to get 1 more flight out of mine, that was 6 months ago! There is so much epoxy and electrical tape on it now the only damage it gets is the prop shaft(doesnt even seem to matter which orientation it hits the ground in )
Out first thing tomorrow with the new fuse and 2409, cant wait to see the difference. A mate is coming who has just bought a Katana, should be interesting to see how his introduction to r/c goes with it
(in reply to ash99)
