MattUpson
Joined: 12/31/2004 From: KetteringNorthants, UNITED KINGDOM Status: offline
HI all, Problems First flight with plane today, well not flight, more taxing. Went to a local park and tried it there, few problems; -Not level ground and winds, plane tipped over. -Ground too bumpy, plane didnt move foward, just tipped fowards. Then went to local football pitch, seemed better, still no good; -Ground still not smooth enough for plane. Then tried it on car park; -Increased throttle, prop fell off! -Did not run straight, constantly going left. -Prop came off again, looked at motor and that was offset to the left. Over all no flight, but a few insights to some problems. I fixed all of them by; -Tightning screws on right of motor mount, moving the motor into centre. -Adjusted wheels so it now runs straight. -Tightend prop onto motor more. Conclusion Reasonabley level ground needed if take off is what you want, if not hand launch would be easier. Make sure everything is straight, true, and adjusted correctly before flying. Thanks, Matt
