Schteeva
Joined: 2/27/2005 From: Abbotsford, BC, CANADA Status: offline
Thanks for the reply DrDoom. Piano wire? That's a surprise! The trailing link looks really good. Thanks for the previous pics. For the main gear I glued two small balsa pieces on the top and bottom of the wire between the fairings and the fuselage. After trimming and sanding the balsa, the result was a thin little airfoil that looked a little more realistic. I don't like the stick-leg look on a plane than is moderately manufactured to scale. The gear looks much better now, and all that is missing is the steerable nosewheel! I will try to send some pics on what I have done so far, and the nosewheel if it turns out half as good as yours ( - this is not the look of anger, but sheer determination!) -Schteeva Abbotsford, British Columbia
