I_Love_My_ABC
Joined: 2/23/2005 From: Sydney, AUSTRALIA Status: offline
Yeah, I did a similar thing with mine. First flight I got it up in the air OK but the controls were different from my other planes and I got confused, instead of up elevator I was actually cutting the throttle so she stalled and nosed into the ground at high speed. Bent prop shaft, smashed cowl, broken prop, broke the right wing off at the fuse and creased the rudder and elevator. I was suprised at how well it all glued back together though... A bit of five minute epoxy fixed the wing and I braced the rudder and elevator with a very thin strip of gaffer tape from tip to tp and over the rudder tip. I also taped the cowl back together from the inside with gaffer tape reconstructing the 90% of the plastic pieces I managed to find and painted over the remaining missing parts with white glossy modelling paint which worked really well because they don't sell replacement cowls for this plane for some reason, you have to buy the entire fuse. I managed to bend the prop shaft and adaptor back into shape and installed the spare prop. This time I spent a couple of hours on FMS flying the Cessna with the TX plugged into my computer, something I should have done originally, and got used to the new control configuration. Finally I covered the plane's fuse and wing in clear packing tape to give it some added support and strength as the wing totally broke in two and I took her back out to the park. With my fingers crossed. I threw it up in the air and it took off well. This time the plane climbed with authority. After some minor trimming it was rock solid in the air, dead stable and flying like a dream. The clear packing tape has made it really shiny and a lot more realistic to look at, especially in the air, almost like it's covered in Monokote and it feels ten times stronger than it was before!! Stick with it live2fly, this is a great little flyer when you get used to it. I only have the 3 channel version but I'll convert it over to 4 channel when I've got a few more hours up on it. I really need to crash it a few more times so I can justify buying a new fuse, 4 ch wing and feathers, but while it still flies I'll leave it as it is....
< Message edited by I_Love_My_ABC -- 7/1/2005 8:39:49 AM >
