large scale pinned hinges
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> large scale pinned hinges
Page: [1]
Login
large scale pinned hinges - 8/6/2002 7:58:56 AM
2lo
Status: offline
What is the best method for installing pinned hinges into large control surfaces, with foam wings?
any insight would be 20/20
       Post #: 1
large scale pinned hinges - 8/7/2002 9:28:49 PM
MinnFlyer
Status: offline
I use the GP Slot maching to cut the slots with. Then install the hinge with epoxy. If you want a little insurance, you can then drill a small hole through the control surface and hinge and epoxy in a round toothpick to lock the hinge in place.
_____________________________
Mike B.
AMA# 42400 www.gettingairborne.com
"Those are my principles. If you don't like them, I have others." - Groucho Marx
(in reply to 2lo)
       Post #: 2
large scale pinned hinges - 8/8/2002 4:34:30 AM
2lo
Status: offline
MinnFlyer
Thanks, yes I agree the slot machine makes short work of it.
I'm putting together 29% AW edge, and the trailing edge of the wing wood material is only a 1/4" thick. Do I add extra material to the back of this before I glue it on? or will the epoxy be strong enough?
I ran a little quick test of my own. I glued one side of a hinge to a piece of 3/8" tristock with probond (polyurathane) let it set up. I can't pull it back out with out breaking the wood. that is with just half of the hinge being in the wood.
I'm just not sure about the 1/4" wood.
What do you think?
(in reply to 2lo)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.250RCU2
