Sport Jett 46 prop
Tower Hobbies
Logged in as Guest
  Printable Version
Touchstart Remote Controlled Autostart Engine .61 ASP COLLECTORS !!!!!!!!!!!!!!
Seller:  vidal_felipe
Details:   $499.00   |  7/14/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Jett Engineering Support >> Sport Jett 46 prop
Page: [1]
Login
Sport Jett 46 prop - 8/6/2002 9:36:34 AM
Spraytec
Status: offline
Broke in my Sport Jett 46. Now I need advice on prop for Hi speed runs in Whiplash Delta. Plane is approx. 3 3/4lbs, I am using the stock muffler (red. Maybe APC pylon ? 8.8 in with 8.75-9.25 pitch? Wildcat 15% nitro
_____________________________
Mike Longnecker
76O-992-9176
       Post #: 1
Sport Jett 46 prop - 8/6/2002 5:14:17 PM
bob27s
Status: offline
Hi Mike.....
there are a variety of combinations you can try.
I would say to start with a standard APC 9x7, and perhaps then try an 8.8x8.5 pylon prop or the 8.75x9W. Try and keep the SJ-46 engine in the 17K rpm (peak, on the ground) range... or slightly above. You can keep adding pitch as long as you stay in that rpm range. Another prop that works pretty well is the 8.5x7.25 pylon prop. The engine will really turn that sucker, and it will unload big time in the air.
You may also want to post the question in the Extream Speed forum. There is quite a bit of experience in there
http://www.rcuniverse.com/forumdisplay.php?forumid=162
I trust this will be helpful.
Bob
(in reply to Spraytec)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.172RCU1
