Unbelievable Velox
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> IMAC >> Unbelievable Velox
Page: [1] 2   next >   >>
Login
Unbelievable Velox - 9/26/2004 12:22:59 AM
lazun
Status: offline
Simply the best flying plane ever!!! 46lbs empty 49.5lbs gross fuel, smoke. ZDZ 210.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 1
RE: Unbelievable Velox - 9/26/2004 2:02:43 AM
newshoundaussie
Status: offline
How do you like the zdz210, what mufflers are you using. Interest in this engine for a 40% yak.
(in reply to lazun)
       Post #: 2
RE: Unbelievable Velox - 9/26/2004 2:27:29 AM
lazun
Status: offline
Using headers and JB cannisters from RCShowcase. 3 blade Mejzlik 32x12 new style blade developed specifically for 210. Never had a problem. Best engine I ever ran. Oh, quiet as can be!!! I am not joking to say that some electrics at our field are louder!!!!!!!!! Power is great.
(in reply to newshoundaussie)
       Post #: 3
RE: Unbelievable Velox - 9/26/2004 3:04:46 AM
newshoundaussie
Status: offline
Is your velox from a aerotech kit. Ordered a 40% yak from them they said they are using a 3w 200 QQ in it. Was going to use a da 150 but may lack some power, as this plane may come in a bit over 40 lbs. By the way great smoke shot!
(in reply to lazun)
       Post #: 4
RE: Unbelievable Velox - 9/26/2004 3:26:03 AM
lazun
Status: offline
Krill Manf.
http://www.krill-model.com
       Post #: 5
RE: Unbelievable Velox - 9/26/2004 4:55:52 AM
Joe Kelley
Status: offline
Lazun, your plane looks beautiful! Great smoke!
Nice models. The pink one with the female pilot that is pictured on the site was owned by a man in my club. Very very nice work. THat 33% looks nice. !~)
Thanks for the link!~~!
Joe
(in reply to lazun)
       Post #: 6
RE: Unbelievable Velox - 9/26/2004 6:47:56 AM
DaveMiller
Status: offline
Hello,
I have both the 35% Velox and 42% Velox and they are fantastic planes. More people are seeing this everyday. I see posts about the plane and nothing but good stuff. I can't speak for the krill other than I know its bigger than Aerotech and alot more expensive. If you ever want a plane that will give you the WOW factor this is it. Also Im on the list for a 40% Yak also from Aerotech on the december run.
Dave Miller P.A.
(in reply to Joe Kelley)
       Post #: 7
RE: Unbelievable Velox - 9/26/2004 3:54:16 PM
lazun
Status: offline
Sebastiano Silvestri said it is the best compromise between pattern and 3D flying in an aircraft to date. He is currently developing a Katana with Krill. The Velox builds a little nose heavy so keep things back.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to DaveMiller)
       Post #: 8
RE: Unbelievable Velox - 9/26/2004 7:48:52 PM
JOHN BLAKE
Status: offline
Hi Lazun,
The RCS velox looks fantastic these days. Its great to see it flying again.
I have put a picture below of the new Krill Katana which I am starting to take orders for. Seba plans to be at the master with the new Katana.
Kind Regards, John.
Click for fullsize
(in reply to lazun)
       Post #: 9
RE: Unbelievable Velox - 9/28/2004 5:31:17 PM
lazun
Status: offline
The manufacturing of these kits are simply amazing. It will blow anything away when you see the quality. Krill is a legend in the composite business, mostly industrial stuff. The model plant is a thing on the side for him. His kits are light and super strong. Look at the ratio of carbon and kevlar in his kits. I know it is not a judgment of strength, but his designs are well thought out. How often do you here of a Composite-ARF falling apart!!! I here it a lot and have seen it a lot!!! Five times!!! And I am tired of hearing that people are not flying them correctly. If you cannot fly these things around and ring them out the plane is simply not built strong enough. Could you imagine Tucker worrying about his equipment? Sebastiano rung the Velox out at the TOC in Europe and you would cringe. Solid as a rock!!!
(in reply to JOHN BLAKE)
       Post #: 10
RE: Unbelievable Velox - 9/29/2004 12:49:59 AM
Velox Pilot
Status: offline
Hello,
I have the 35% velox from Aerotech. I have had it 2 1/2 years with over 300 flights. This is a great design from them. Mine has a 3W106 now with cans with Duralites at 27lbs I have unlimited vertical. Can't go wrong with this plane.
Later
Ted
(in reply to lazun)
       Post #: 11
RE: Unbelievable Velox - 9/29/2004 3:34:14 AM
lazun
Status: offline
The lines of the Velox are exceptionally beautiful.
(in reply to Velox Pilot)
       Post #: 12
RE: Unbelievable Velox - 9/29/2004 11:02:41 PM
xtra 330
Status: offline
SO HOW MUCH???
(in reply to lazun)
       Post #: 13
RE: Unbelievable Velox - 9/30/2004 1:38:43 AM
IFlySlowPlanes
Status: offline
"If you have to ask......"
(in reply to xtra 330)
       Post #: 14
RE: Unbelievable Velox - 9/30/2004 2:05:52 AM
lazun
Status: offline
My wife designed the tears and all the accents. If you look closely you can see she named the plane appropriately: "Insanity"
(in reply to IFlySlowPlanes)
       Post #: 15
RE: Unbelievable Velox - 9/30/2004 4:18:57 AM
