JonesE
Joined: 12/12/2004 From: , ON, CANADA Status: offline
Thanks for the video Kol. I can definately hear your car changing gears. My car is NOT doing this. Your car is going extremely fast compared to mine. Maybe once my clutch gets fixed, it will get into second gear. Here are some more pictures I took to clarify things. The shaft is 5mm The thing going on the shaft is 5.4mm (I measured it the proper way this time) Here is a picture of another thing that has the correct diameter and this one fitso n the shaft w/o any wobbling. I don't see how I am supposed to put a 5.4mm thing on a 5mm shaft and expect it not to wobble. Edit: As forthe shifting you talked about screwing it in. Don't I want to screw mine OUT so it will shift easier? Right now I can't get into second gear so don't I want to unscrew it? This loosens the spring and allows the metal clutch shoe to come out easier using less RPM.
< Message edited by JonesE -- 11/1/2007 9:28:02 PM >
