RE: Official Smartech Thread
Tower Hobbies
Logged in as Guest
  Printable Version
HPI SAVAGE 14MM HEX HUB WHEEL EXTENSIONS - RTR
Seller:  wheelextensions
Details:   $22.00   |  10/23/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> RE: Official Smartech Thread
Page: <<   < prev  149 150 151 [152] 153 154 155 156 157 158   next >   >>
Login
RE: Official Smartech Thread - 11/3/2007 2:11:11 AM
GYNAIKAS
Status: offline
Not nessecerily (did I spell this right? ), you should check their condition first, clean them and see how they work.
_____________________________
I simply love perfection...do something as good as you can or don't do it at all...
(in reply to Kol)
       Post #: 3776
RE: Official Smartech Thread - 11/3/2007 3:02:19 AM
enzosrock
Status: offline
Hey what kind of tires are you guys runnin
(in reply to Kol)
       Post #: 3777
RE: Official Smartech Thread - 11/3/2007 3:29:06 AM
hibityhupla
Status: offline
30mm foams 40 shore. I needed the wheel extensions otherwise go with a 26mm foam. I tried tons of rubber tires. Best rubber ones I've found are through dinball on ebay. 26mm topcad aluminum wheels and tires. The rubber always ends up coming off the rims on everything I've tried though. Foam seems to get better grip too.
(in reply to enzosrock)
       Post #: 3778
RE: Official Smartech Thread - 11/3/2007 10:57:02 AM
GYNAIKAS
Status: offline
At the front 24mm tyres are better cause they make steering easier...
(in reply to hibityhupla)
       Post #: 3779
RE: Official Smartech Thread - 11/3/2007 2:53:42 PM
ferrarimk13
Status: offline
is it me or are the 30 mm tires a bit big for the back? when i had the plastic radio tray, it would constantly rub, so are my tires maybe a bit bigger than that in the back?
press Alt+F4 for a good time.
(in reply to GYNAIKAS)
       Post #: 3780
RE: Official Smartech Thread - 11/3/2007 3:42:12 PM
GYNAIKAS
Status: offline
No they are just fine you've seen the pics of mine...these are 30mm ones rear.
(in reply to ferrarimk13)
       Post #: 3781
RE: Official Smartech Thread - 11/4/2007 12:14:00 AM
ferrarimk13
Status: offline
oh, then i might have even larger rear foams, who knows.
       Post #: 3782
RE: Official Smartech Thread - 11/4/2007 1:04:45 AM
GYNAIKAS
Status: offline
You have the graphite tray so bigger foams can fit. With the stock tray, 30mm is the maximum rear tyre width without ofset parts use. I think 30mm are ideal for track use.
       Post #: 3783
RE: Official Smartech Thread - 11/4/2007 4:53:47 AM
Fat Boy
Status: offline
I've just acquired a Smartech 1/5 scale "Ranger" 2WD with a 23cc gas motor. Problem is, I've got the car and a "Challenger" TX but no manuals for either.
I've already checked the site but can't seem to find anything to help.
Jeff
(in reply to rctamiyafan77)
       Post #: 3784
RE: Official Smartech Thread - 11/4/2007 11:18:22 AM
Kol
Status: offline
quote:
ORIGINAL: Fat Boy
Jeff
Is there any particular info that you are looking for? Download a manual from another manufacturer for a similar model. It will have plenty of info in it.
(in reply to Fat Boy)
       Post #: 3785
RE: Official Smartech Thread - 11/5/2007 2:15:09 PM
Dkishton1486
Status: offline
Another question, Is the clutch bell supposed to be moving constantly with the engine running or should it be like an actual clutch and be able to be stopped with the engine running? Because I ran mine yesterday and the clutch bell was constantly moving and I swear I coulf have recalled before I took it all apart it would only engage when I gave it some gas....
(in reply to Kol)
       Post #: 3786
RE: Official Smartech Thread - 11/5/2007 3:22:47 PM
boltech
Status: offline
Yes the clutch bell should always be easy to turn. With the buggy off you should be able to spin it freely, mind you the wheels will turn as the clutch bell is still in mesh with the tranny.... If you push the buggy or car while it is off it should be able to roll for up to a meter. You will notice while it is rolling that the clutch bell is also turning. Note that the actual cam shaft of the engine is not turning.
quote:
ORIGINAL: Dkishton1486
Smartech Commando, HPI RS4 3 18SS, Thunder Tiger SSB, Marui Samurai, PRP Swift Pro, Tamiya Subaru Impreza WRC MC'07 13T TT01
(in reply to Dkishton1486)
       Post #: 3787
RE: Official Smartech Thread - 11/5/2007 3:34:23 PM
Dkishton1486
Status: offline
So when its stared the clutch bell shouldnt be turning as fast as the engine it?
(in reply to boltech)
       Post #: 3788
RE: Official Smartech Thread - 11/5/2007 3:41:08 PM
boltech
Status: offline
During idle the clutch bell may rock a bit but should not be turning. Once you tap the throttle and the clutch shoes come in contact with the clutch bell, then the bell will turn.
