RE: Official Smartech Thread
Tower Hobbies
Logged in as Guest
  Printable Version
HPI SAVAGE 14MM HEX HUB WHEEL EXTENSIONS - RTR
Seller:  wheelextensions
Details:   $22.00   |  10/23/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> RE: Official Smartech Thread
Page: <<   < prev  149 150 151 152 153 154 155 156 [157] 158   next >   >>
Login
RE: Official Smartech Thread - 3/29/2008 8:10:45 PM
Hibityhupla!
Status: offline
I have been thinking about your 2 engine car since I read your post. One quick question---You didn't use 2 smartech engines did you? If that's the case that os 18tz-tx would still have you beat. I think the stock Smartech engine only has .85hp with a max of 28,000rpms. The 18tz-tx has 1.8hp with a max rpm of 34,000. So with 2 smartech engines you would have 1.7hp but it would still have the 28,000rpm limit. I'm not saying it's a bad idea, I just hope you didn't go with the stock engines. The best way to do it would be to find an engine with around 1hp but good to around 40,000rpms. If you do the math the stock smartech can pull 30mph at max rpm. so if you divide rpms by mph it comes up to around 933rpms=1mph. So the OS would have you by at least 6mph with the stock gearing. Just a thought....
(in reply to Hibityhupla!)
       Post #: 3901
RE: Official Smartech Thread - 3/29/2008 9:20:01 PM
buggyman2
Status: offline
hi guys ive got a winner 1 2 speed just wondering were i can get that bit that the wheel bolts on
       Post #: 3902
RE: Official Smartech Thread - 3/29/2008 11:16:50 PM
r20crazy
Status: offline
you gotta be more specific than 'the bit'. you mean the axle/hub? the nut for the axle? the 'hex' part? what exactly you mean? if your not sure what its called, post a pic pointing out what you are speaking of
(in reply to buggyman2)
       Post #: 3903
RE: Official Smartech Thread - 3/29/2008 11:54:57 PM
buggyman2
Status: offline
yer the bit that the hex goes on
(in reply to r20crazy)
       Post #: 3904
RE: Official Smartech Thread - 4/1/2008 3:35:53 AM
Hibityhupla!
Status: offline
SMARTECH CAR PARTS 1/10 WINNER PRO PARTS 45061
Our Price: $6.99
rcworld has them....I think this is what your talking about....
       Post #: 3905
RE: Official Smartech Thread - 4/1/2008 10:11:13 AM
buggyman2
Status: offline
yer u no the bit that the shaft goes in and the bit were u put the nut on the other side
       Post #: 3906
RE: Official Smartech Thread - 4/1/2008 11:40:26 AM
pede_187
Status: online
where does everyone get their parts?
(in reply to rctamiyafan77)
       Post #: 3907
RE: Official Smartech Thread - 4/1/2008 7:41:23 PM
buggyman2
Status: offline
yer plz help me ill try get the a pic of the part and i need somewere in england
(in reply to pede_187)
       Post #: 3908
RE: Official Smartech Thread - 4/3/2008 6:42:42 PM
CenTrMTL
Status: offline
witch drive cup goes from trany to back diff and also the shaft goes from diff to trans ...for winner pro
because they dont tel no where witch one goes there
thanks alot
       Post #: 3909
RE: Official Smartech Thread - 4/4/2008 9:24:35 AM
Hibityhupla!
Status: offline
quote:
ORIGINAL: BuggyManQC
thanks alot
I think you mean these--- SMARTECH PARTS 1/10 CAR WINNER PRO 11260 SPEEDY TIGER
(in reply to CenTrMTL)
       Post #: 3910
RE: Official Smartech Thread - 4/6/2008 12:10:44 AM
Hibityhupla!
Status: offline
Ran into a problem with the bigger bell. The 20t gear won't fit.... It has a 12mm center but the threads are different. Would it be easier to change the threads on the bell or inside the gear? The losi lst bell does work good with the R40 24t and rs4 19t gears though. I just want more...lol
       Post #: 3911
RE: Official Smartech Thread - 4/8/2008 3:34:22 PM
CenTrMTL
Status: offline
Thnaks alot bro
       Post #: 3912
RE: Official Smartech Thread - 4/9/2008 10:26:26 PM
Hibityhupla!
Status: offline
quote:
ORIGINAL: pede_kid
rcworld or ebay
       Post #: 3913
RE: Official Smartech Thread - 4/14/2008 10:47:05 PM
Hibityhupla!
Status: offline
Got the car broke in with the os 18tz-tx. Night and day difference all the way through. That os was pulling more speed in first gear then the stock engine was in second.
       Post #: 3914
RE: Official Smartech Thread - 4/25/2008 1:25:32 AM
