RE: Official Smartech Thread
Tower Hobbies
Logged in as Guest
  Printable Version
HPI Racing Baja 5B - RTR
Seller:  lisa2803
Details:   $799.99   |  11/22/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> RE: Official Smartech Thread
Page: <<   < prev  149 150 151 152 153 154 155 156 157 [158]
Login
RE: Official Smartech Thread - 7/4/2008 5:28:40 PM
Smartechracing
Status: offline
For the magic wheel, we change a new name and new color. Later will have Ford F350(2008 version) car body on it.
_____________________________
Manufacturer of RC Cars
A member of Perfect international group
(in reply to R.lepecha)
       Post #: 3926
RE: Official Smartech Thread - 7/5/2008 4:42:00 PM
R.lepecha
Status: offline
quote:
ORIGINAL: Smartechracing
Woo lol will the body be stronger? i liked the body it came with i made it look mint but then it broke!!! it wasnt wery flexible
(in reply to Smartechracing)
       Post #: 3927
RE: Official Smartech Thread - 7/7/2008 7:26:39 PM
jaimepn
Status: offline
Well gang it is time to say goodbye to the SMARTECH 4wd ON road car I have, It is in great shape and has a Aluminum Tuned Pipe, and an OS carb added to it, It has minimum wear and has never been broken, engine has about 10 tanks run through it and wil lstart on the first pull and idles like a dream. I was going to list on EBAY, but I thought I would give all of you first crack, I can throw in some parts, clutch shoes, clutch bells, dogbones and I wil see what other spares I bought. Ready to Run! For $125..plush you pay the shipping.. Email me at jaimepn@yahoo.com if you are interested..
       Post #: 3928
RE: Official Smartech Thread - 7/12/2008 6:09:22 PM
Smartechracing
Status: offline
quote:
ORIGINAL: R.lepecha
Yes, the body will be stronger.
       Post #: 3929
RE: Official Smartech Thread - 7/17/2008 11:39:19 PM
rasta
Status: offline
I bought a smartech car a while ago, ran it a few times and didn't quite break the engine in all the way because it wouldn't start anymore. I took all the necessary precautions when breaking the engine in, and I pretty much tried everything to get it to start. Ever since then it has been sitting in my closet. I want to run it again and I'm pretty sure it needs a new engine. Does anybody have any advice for me on what I should do?
       Post #: 3930
RE: Official Smartech Thread - 8/1/2008 9:24:23 PM
Hibityhupla!
Status: offline
Start by taking the glow plug out and check to make sure it's still lighting up. I found that 9 out of 10 times if the engine won't start a new plug will cure it. If thats good check your fuel adjustment. Should be around 2 1/2-3 turns open. I have one that's a couple years old with the original engine that still runs and starts on first pull but it's getting so worn out I set the fuel needle at 1 1/2-2 turns open. Gets a little hot but runs great. I would try to lean it out a little before i bought a new engine. So check your plug, prime it, lean it out and let it rip....If your planning on getting a better engine anyways might as well use the stock one for learning. My first nitro car I had leaned out so much it ran at 330F. I know it's bad but it ran forever like that and when it did blow up I wasn't out anything because i had a spare sitting here.
(in reply to rasta)
       Post #: 3931
RE: Official Smartech Thread - 9/23/2008 3:20:02 PM
R.lepecha
Status: offline
well people no ones posted ina while so i just guna say i craked da cb with the stok shoes so getting a traxxas 18 touth for itt wo lol
(in reply to Hibityhupla!)
       Post #: 3932
RE: Official Smartech Thread - 9/25/2008 9:47:41 AM
pwr2satsfy
Status: offline
Hello, does smartech titan have 1 or 2 gears?
(in reply to rctamiyafan77)
       Post #: 3933
RE: Official Smartech Thread - 9/28/2008 1:47:09 AM
Hibityhupla!
Status: offline
looks like a single speed to me... I found it on ebay with a bunch of pics.
Smartech 1:5 4WD TITAN RC gas No Nitro Truck Car NEW
just copy and paste at ebay. pictures show a lot.
(in reply to pwr2satsfy)
       Post #: 3934
RE: Official Smartech Thread - 9/28/2008 3:44:02 AM
NightHawk18
Status: offline
so i just got a smartech ftom my buddy who had lost alot of parts for it and destroyed the gears, so i used servos off my cen and other misc stuff off my old cars and i somehow built a gear box,
my question is what are the factory settings for the engine. most are like 3 1/2 out for the high end but i have no idea on this car.
also i have no low end idle needle...its just gone there is the hole for it but that's it or its the one that should have the spring around it.
       Post #: 3935
RE: Official Smartech Thread - 10/2/2008 10:21:14 AM
Hibityhupla!
Status: offline
the stock engines are nothing to write home about..lol You would be better off getting an OS 18cv-rx or something better. Save yourself a lot of hassle.
(in reply to NightHawk18)
       Post #: 3936
RE: Official Smartech Thread - 11/30/2008 11:54:50 AM
rp11112
Status: offline
I have a rapid VH-A6, I think it is related of made by the same company. It has a purp head and the engine jut says .18. It uses all the same parts as those but it has a 2 speed transmission. What 18 engine will work for it with the stock 2 speed cutch and transmission. it uses the same two speed transmission and clutch as the smar tech speedy tiger. I think it is a offshoot of smartech called FMT world racing, www.rccarmax.com/index.php?cPath=29_62&sort=2a&page=2. What .18 size engines will work with this clutch system and tranmission?
Here is a site with picks of what it looks like: www.lelong.com.my/Auc/List/2009-07DSale16497411.htm Also this model came with metal clutch shoes. i think this is almost the same car as the smartech winner 1. Does anyone know where to get the replacment carb for the .18 engine?
< Message edited by rp11112 -- 11/30/2008 2:50:39 PM >
(in reply to Captain_Nifty)
       Post #: 3937
RE: Official Smartech Thread - 12/2/2008 9:14:20 PM
benk
Status: offline
most .18 size engines will fit with the standard clutch system. The easiest way to find a carby for the engine is to measure the throat of the carby where it goes into the engine and match one up with the same size
Ben''s RC
For all your Smartech Parts
(in reply to rp11112)
       Post #: 3938
Page:   <<   < prev  149 150 151</
