johnxbox
Joined: 3/24/2004 From: Lancashire, UNITED KINGDOM Status: offline
hi again magic, did it arrive then? i will use t-maxx parts but i havnt needed to try and fit any yet. i may need to tho as you will prob read lol. I have broke the left rear stearing arm. the bit where the scrw goes into is realy thin and weak. however i superglued it where it had cracked aaround the screw (the small creasnt shaped peice of plastic was still around the screw inside the ball end which is connected the stearing column shaft so i had it to glue back to the rest of the stearing arm after i had removed the screw. then after the super glue had set i fixed the shaft back to the arm, however this alone would not stand up to the beating it would get so i used something which is made by loctite which you work in the palm of your hand to a soft plasticine consistancy, then in 10 mins it sets hard as realy tough plastc, so that did the trick. other than that iv ran half a gallon of fuel through no probs although i still havent got it tuned exactly right just yet! I am considering trying to do a reverse upgrade but i havent heard of any1 who has done it yet so i dont know. I have a spare servo and thereis always t-maxx parts going on ebay so its a poss.
