Johng
FL, USA Status: offline
A few more thoughts - My position is influenced by my experience with a 4m scale glider that just happens to weigh in at 11 lbs. That is with 4 lbs of battery and motor aboard. It's got a rediculously flat glide at it's happy speed somewhere around 45-50 mph. It can also take a hard pull-up at 90 mph that just looks horrible from a wing-bending perspective. I have a picture of this somewhere, but apparently, not scanned. So, I know that a good, efficient, survivable and controlable plane can be built like this. Aspect ratio around 18, and lands nicely, although I avoid yank-n-bank below treetop height. I do put it through it's paces up high, cuban-8s and other classic aerobatics are very nice. I'm not a "sailplane guy" though. I fly a lot of different stuff. I've often thought that the 4m sailplane would make a nice UAV testbed. The Oswald factor is something that is an approximation in this case - because we didn't get it from testing. However, that's where engineering judgement comes in. Do you really think it makes a material difference that I used an estimate of .8 for e, when the real 3d flow might say .77 or .82? That's what I call bad engineering. Chasing down answers to the n'th degree when a ballpark figure is just as usefull. A 5% error in e becomes a 1% error in CDi which becomoes a .2% error in the overall L/D - range consideration. So, who cares? I don't mean any disrespect to Stefano and Profili at all though. I'm a customer and love his program. As for the weight considerations of a Drela wing, the Aegea 3m wing can be built at 25oz for structure, or about 1.5 lbs. That's a pretty reasonable budget for an 11 lb plane like this. If you figure the bare structure must weigh about 3lbs, half that for the wing isn't bad. That's for a wing that will take a 200 lb load. Build this wing and you have a wing that will go to 18 g's or so. So, you could build it even lighter. I do think that another improvement on Maynard's design may be in the airfoil area. Didn't feel much like sorting thru those today though. Sheesh, I been posting and figuring on this thread for a long time. I gotta get some stuff done around here.
_____________________________
John
