Johng
FL, USA Status: offline
Hello, there is no doubt that a higher AR wing would have done better here. In fact, this same mission was accomplished by a UAV company called Insitu Group some years ago using a set of modified sailplane wings, from RnR I believe. Even among the RC sailplane set, the differences in AR are well known. 2M sailplanes cannot compete with 3m open class ships. I've spent a few afternoons with what is considered a very good performing 2m sailplane watching in envy as the 3m guys sailed easily from thermal to thermal. If you want to compete in 2m, get a 2m. If you want to have fun soaring get a 3m or larger plane. Back to the subject- The interesting thing about Maynard's record is that it is an FAI record. I can't believe no one brought this up yet. What that means is that it was done within FAI limitations. That means less than 5 kg total weight, less than 10 cc motor and LESS THAN 2m WINGSPAN. That is the major reason for the lower than optimum aspect ratio. That wing is exactly what one would expect for an optimized wing under a wingspan limit - with maybe the exception of winglets. Without those limits I could probably modify a 4-5 m sailplane to do the same thing. But Maynard is the one who did it, so hats off to him!
_____________________________
John
