video: 20 ft wingspan B-24 crash on maiden flight....
Tower Hobbies
Logged in as Guest
  Printable Version
Fei Bao F-4 Phantom scratch & Dent - ARF
Seller:  rcjetmodels
Details:   $3,322.00   |  10/14/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Crash & Rebuild >> video: 20 ft wingspan B-24 crash on maiden flight....
Page: [1] 2 3 4 5 6 7   next >   >>
Login
video: 20 ft wingspan B-24 crash on maiden flight.... - 9/27/2004 1:59:53 AM
teryn1
Status: offline
< Message edited by teryn1-RCU -- 10/30/2004 7:49:18 PM >
       Post #: 1
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/27/2004 2:13:58 AM
ifixairplanes
Status: offline
nice...i got to it before everyone else ate up the bandwidth!!
WOW! that vid. is a keeper! Nothing at the scene but silence and destruction. I wonder what happened....
sean
_____________________________
"We request that model aviation not be innocently sucked into a black hole of regulation..."
(in reply to teryn1)
       Post #: 2
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/27/2004 2:27:14 AM
SilverEagleBW
Status: offline
WOAH! Wonder what his wife said when he got home!
(in reply to ifixairplanes)
       Post #: 3
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/27/2004 2:55:09 AM
teryn1
Status: offline
the wife doesn't care. he does what he wants. He has the time and money.
(in reply to SilverEagleBW)
       Post #: 4
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/27/2004 3:34:55 AM
CrashPro
Status: offline
oh man....that is sad.....looks like pall bearers carrying their best friends casket at the end
       Post #: 5
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/27/2004 3:52:40 AM
TOPGUNNER
Status: offline
Not trying to be mean, but that looked like old man syndrome....... "Pilots Error"
< Message edited by TOPGUNNER -- 9/30/2004 11:14:26 PM >
Every time I close the canopy before taking off, I feel that i'm closing the lid on my own coffin.......
(in reply to CrashPro)
       Post #: 6
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/27/2004 4:05:28 AM
William Robison
Status: offline
If you watch the wings on taxi out, they are flexing a lot. And when the plane goes into its left roll to the end you can see the ailerons are at full right, against the roll.
With these points in mind, I suspect the outer wings were not secure, one or the other slipped out of place causing the roll and spiral.
Bill.
Real Airplanes have Two Engines
AMA 25139 - More than 40 years.
(in reply to TOPGUNNER)
       Post #: 7
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/27/2004 5:18:15 AM
Underaged Pilot
Status: offline
drats it was at 77% and failed trying again
(in reply to William Robison)
       Post #: 8
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/27/2004 6:47:56 AM
randall1959
Status: offline
At that span of twenty feet a little flexing of the wings would probably be normal. Even full size aircraft with big wingspans have a bit of give in the wings to keep them from breaking off during flight. It appears to me more than anything that this fellow didn't have quite enough airspeed when he made that turn. He should have probably tried to make that turn a little flatter to keep his airspeed up. Maybe he just wasn't experienced with really really big models. I'd say that plane had to be pretty darned heavy to be flying in a bank as slowly as it was. If he was using reverse aileron instead of rudder, that, to me, speaks of inexperience in flying really large planes. Or maybe it just all happened so fast that he misjudged his attempted correction. Most of the really big planes require coordinating rudder in turns.
I meant to do that.........
(in reply to Underaged Pilot)
       Post #: 9
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/27/2004 2:51:28 PM
JeffH
Status: online
Looked like too much bank and maybe a tad tailheavy. He pushed the nose down just after takeoff, but then it kind of climbed back up as he started his turn. Ran out of lift, altitude and ideas all at the same time.
(in reply to randall1959)
       Post #: 10
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/27/2004 3:25:31 PM
rsallen13
Status: offline
I agree with JeffH. Not enough airspeed and tail heavy.
But what gets me is right at the start. A motor run up being held by one older flyer with three guys right in front of it with the building behind them. It the holder had lost his grip the bystanders would have been toast with no where to go.
(in reply to JeffH)
       Post #: 11
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/27/2004 4:23:47 PM
randall1959
Status: offline
It kinda makes me wonder if the plane wasn't really underpowered to begin with if it only took one guy to hold that massive bird back.
(in reply to rsallen13)
       Post #: 12
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/27/2004 4:46:03 PM
volkan
Status: offline
quote:
ORIGINAL: randall1959
that also got me worried!! what if he left go!! all those people right in front on the props!!!!
Volkan Dil
Al's Hobbies Jet Centre IT - www.alshobbies.com
       Post #: 13
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/27/2004 4:47:37 PM
volkan
Status: offline
quote:
ORIGINAL: teryn1-RCU
NOTE: if bandwidth gets exceeded due to excessive downloads, I will have to pull the video off server til next month. you will know this has happened when you are not able to get the file.
Let us know, and i will put it up on my server.
Volkan Dil
       Post #: 14
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/27/2004 5:21:31 PM
MikeMc
Status: offline
Just a few random thoughts...
1. Note how safety was the highest priority. Engines run up with the nose pointed right into the hanger with pilot and others 3 feet in front of 4 giant props.
2. Again safety. Note how on takeoff the plane was coming almost directly at the camera man.
3. Most importantly. The B-52 and now this. It's just not acceptable. When you crash something like this make 100% sure you get the impact on video. No going down behind trees or car.
Sponge Mike Square Pants - Insubordinate Renegade Airforce (IRA 1)
(in reply to volkan)
       Post #: 15
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/27/2004 6:43:59 PM
teryn1
Status: offline
quote:
ORIGINAL: volkan
Thanks, will let you know. In the last posts you guys are hitting on the main points. Notice that the pilot didn't even give himself the benefit of the doubt on using the full runway.
< Message edited by teryn1-RCU -- 9/27/2004 6:51:05 PM >
