RE: video: 20 ft wingspan B-24 crash on maiden flight....
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Crash & Rebuild >> RE: video: 20 ft wingspan B-24 crash on maiden flight....
Page: <<   < prev  1 [2] 3 4 5 6 7   next >   >>
Login
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/27/2004 9:03:13 PM
SkyDude
Status: offline
Big plane's maiden flight and they're taking off on a grass runway with a lake on one side and a building/parking lot on the other?
What a bummer, but these guys are just plain lucky someone wasn't seriously hurt. I felt the same way as other posters when I saw the engine run-up right in front of a bunch of people, then the takeoff came right at the camera guy, and then the plane flies over/behind the parking lot. Talk about risking a lot of injury/property damage on a maiden flight.
Too me it looked like a combination of being tail heavy, not enough airspeed on takeoff and not a lot of control surface authority, plus some guy on the sticks that appears to be more of a builder than a flier.
They could have easily ended up with a Darwin award. Dumb-luck kept it from being much worse.
And I second the motion that all crash videos should actually show the crash.
(in reply to teryn1)
       Post #: 26
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/27/2004 9:45:49 PM
David Cutler
Status: offline
I reckon what happened to this aircraft is the same as what probably happened to the B52 giant scale we have seen videos of.
If you look at the turn he is making, it's not a coordinated turn (that is, it's yawing away from the turn) and the inner wing looks like it's stalling. The natural reaction is to give right aileron away from the turn, to try to correct the steepness of the turn, but all that does to a near-stalled inner wing (now, with a down aileron on it) isn't just more lift, but more drag (increase lift = increased drag) thus making the inner wing 'dig in' even more.
I believe a full scale B52 crashed fairly recently for exactly the same reason. Badly coordinated turn (that is not using the rudder to yaw into the turn) = inner wing stalls.
My 2c!
-David C.
       Post #: 27
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/27/2004 10:45:09 PM
Planebeach
Status: offline
There was a full size B-52 that carshed in the mid 90s, too step turn to low. Resolting inn a wing tip stall. I cant belive this idiot putting in 40cc engines , and that he took of on that runway. And then turning into an area that there was a pariknig lot, why not turn towords the lake. He was damb lucky that no one was hurt.
_____________________________
Personlized F-27 Stryker Brushless, Alfa FW-190, Team Losi LST.
(in reply to David Cutler)
       Post #: 28
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/27/2004 11:52:35 PM
MikeMc
Status: offline
Petter, excuse me but if he turned towards the lake he could have lost everything in the crash. If he turned towards the parking lot then it was only human lives at risk. Sheesh.
Sponge Mike Square Pants - Insubordinate Renegade Airforce (IRA 1)
(in reply to Planebeach)
       Post #: 29
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/27/2004 11:54:54 PM
volkan
Status: offline
he he , i would love you watch you fly dave
Volkan Dil
Al's Hobbies Jet Centre IT - www.alshobbies.com
(in reply to MikeMc)
       Post #: 30
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/28/2004 12:14:26 AM
cruzmissile
Status: offline
Mac Hodges has a B-29 with a 20(+-)foot wingspan and he uses all four G-80's in his. It has plenty of power to get it moving through the air. I was at the Ft. Benning Fly-in this past weekend and watched him fly his massive B-29 along with the X-1. The X-1 suffered some damge during the rocket ignition stage, but was recovered in the cotton field without further damage.
I do believe it was a mixture of wrong size engines and using more than one type of engine. This would of lead to slower than normal operating airspeed. Anyways, that's all I have to say about that.
What goes up must come down, and that is the Landing Gear!
(in reply to volkan)
       Post #: 31
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/28/2004 1:25:45 AM
teryn1
Status: offline
Your guys' responses to this video are fascinating....
The purpose of putting this up here is so that we can learn and make better descisions about our own airplanes and approach to flying.
In response to a few posts back, the pilot intended to fly the plane in a straight line. Due to assymetric thrust or bent tail, the plane was yawing to the left causing it to turn to the left against the pilots inputs. If you watch teh video closely, you will see right aileron during the entire flight, but the plane continued to the left.
more info: to the right of the cameraman (during takeoff roll) is a barn structure where onlookers witnessed the flight and crash. I agree it is too bad the plane descended behind the cars prior to impact. So the takeoff happened between the lake and the barn. Regardless if there is a structure there or not, the plane could have turned into the people (like you guys are discussing).
< Message edited by teryn1-RCU -- 9/28/2004 1:32:49 AM >
(in reply to cruzmissile)
       Post #: 32
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/28/2004 2:13:52 AM
exeter_acres
Status: offline
quote:
ORIGINAL: MikeMc
Good point... wouldn't want to lose the important stuff...
Either way...it is sad to see such a beautiful model lost because of what appears to be (at least to a complete n00b) several bad decisions.....
but.......as they said..... We can rebuild it....
       Post #: 33
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/28/2004 2:55:27 AM
Splinter Wood
Status: offline
So how was the Hot Dog roast?
(in reply to exeter_acres)
       Post #: 34
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/28/2004 3:03:02 AM
teryn1
Status: offline
I didn't get to go to the hot dog roast....but I'm sure with all that wood leftover from the wreckage, it would give you a pretty good fire to cook your dog in just minutes
(in reply to Splinter Wood)
       Post #: 35
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/28/2004 3:09:01 AM
CGCOMM3RET
Status: offline
Teryn1-RCU
I am sorry to see such a beautiful plane go down also. I have to agree that it looked like the plane did not have enough power on takeoff, but I alas, am just a newbe to this hobby also and I don't know anything about the big planes. Haven't even flown my trainer yet.
Looks like I live just around the corner from you.
Larry
       Post #: 36
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/28/2004 3:22:44 AM
teryn1
Status: offline
quote:
ORIGINAL: CGCOMM3RET
Larry
I fly at Suburban RC in Grafton, Mole airfield, at Grafton Eastern and Island Rds... Great place, good people. Plenty of people to help you there. Send me a PM if you need more info.
(in reply to CGCOMM3RET)
       Post #: 37
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/28/2004 4:06:35 AM
teryn1
Status: offline
link updated
< Message edited by teryn1-RCU -- 9/28/2004 2:08:41 PM >
       Post #: 38
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/28/2004 5:41:34 AM
Underaged Pilot
Status: offline
shiz I hate the classics behind the tree!!!!!!!!
       Post #: 39
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/28/2004 11:55:56 AM
Vingemutteren
Status: offline
I have put the video up, but only to the 4/10/2004 (this weecend), to give others time to get theirs systems up and go.
Right clik on the link below and chose "save target as" to download this 8.7MB video.
http://home.online.no/~gahildr/assets/multimedia/b24.wmv
Gert
(in reply to Underaged Pilot)
       Post #: 40
RE: video: 20 ft wingspan B-24 crash on maiden flight.... - 9/28/2004 12:00:41 PM
Vingemutteren
Status: offline
Theese who pilot big planes, do they not study howe the fulsize counterparts behave? Thinking of rudder/ailron use for one. Anyway it must hurt to know your masterpiece was not up to the task of flying. Especialy when you know it is your own dam foult.
< Message edited by Vingemutteren -- 9/28/2004 12:06:06 PM >
Gert
(in reply to Vingemutteren)
