William Robison
Joined: 11/10/2002 From: Mary Esther, Florida, FL, USA Status: offline
If you watch the wings on taxi out, they are flexing a lot. And when the plane goes into its left roll to the end you can see the ailerons are at full right, against the roll. With these points in mind, I suspect the outer wings were not secure, one or the other slipped out of place causing the roll and spiral. Bill.
_____________________________
Real Airplanes have Two Engines AMA 25139 - More than 40 years.
