critterhunter
OH, USA Status: offline
Hi all, I'm very new to the RC universe having just bought an Aerobird Challenger a few weeks back. I'm fairly good with the plane now even in expert mode, and decided I just had to have a live mini cam for it. I have a 800mw color camera in route that should get here in a week or so. In the meantime, I need to prepare this plane for flight with the camera. So, I'm hoping some of you can help a newbie get his feet (wings) wet with this project... Mounting The Camera: What is the maximum weight you would suggest carrying with a Challenger? I'd prefer to mount the camera in a safe place while keeping the COG proper. How do I determine the COG of the plane exactly in stock form? The camera comes with a seperate credit card type transmitter. If it and the camera weigh about the same could I mount one under the left wing and the other under the right, very close to the body of the plane for protection? I need ideas, but if under the plane is best then I'll have to (?) put the wheels on the plane to avoid belly landings on the camera. Camera/Transmitter Power Source: I have three options here. I believe the camera runs on 8 to 12v. The easiest way would be to use a 9v battery. However, this adds weight and I hear a lot of the signal drift people get is due to the low amp 9v battery use. That being said, if I power it via the plane battery I have two routes to try...using the X-Port connector or splicing a second power plug to the controller power line. The X-Port connection would be the cleaner, but provides two concerns. Does the power pins off the X-Port pass straight from the battery to the pinout or is it going through electronics on the plane which may overload the controller OR cause more interference? Does anybody know what this plug is called and where I can get the four pin plug for that port (prefer on foot) (Radio Shack, electronics store, etc?) or a web page. The other option is adding a plug to the controller's power plug. Does anybody know where (again, on foot) I can buy this plug, or at least suggest a web outlet? Or, would I be better off using an aftermarket plug style and converting all my packs and charger to that type (Is Dean's the best and most popular out there?)? Noise Reduction: I'm concerned about possible noise interefernce from the plane. Where can I get a small device to eleminate noise (Radio Shack, web, etc) and how do I hitch it up? Power Packs: I currently have 7.2v and 8.4v 900 packs. Since (I think) this camera needs at least 8v, are there any packs out there in the 9v range that the plane can also use? Or, my second option is a 8.4v pack with a higher amp rating. Suggestions on where to get one as I think there is a 1100ma 8.4v out there somewhere? I would assume this is a 7 cell pack but will an 8 (if it is) work with my stock charger? Need to buy the plane more fly time if the cam is feeding off the same battery. Again, connector type concerns or what to switch to? Replacing the RCA plugs on the camera with something other for weight and bulk conerns: I know how to solder. Any ideas or types of plugs at Radio Shack to look for? Upgrading the CMOS cam to CCD: I see many people doing this. Is it a simple plug and play procedure and where can I get a good cheap CCD that has better video quality if I decide to upgrade the CMOS? I know these are a lot of questions but I'm new at all this and need guidance. Thanks in advance!
