Reply to post #18 by MDP
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> General Racing Discussion >> Reply to post #18 by MDP Page: <<   < prev  1 [2] 3 4 5 6   next >   >>
Login
Reply to post #18 by MDP - 8/8/2002 6:56:01 PM
kane
Status: offline
Mike,
I read the rules last night. I think I am missing something. It only states that a motor can't turn over 16,5K on the ground. It says nothing about peak RPM. I know you have said this before. But, why is the TT 40 being used? If the intent of the rule was to keep the Peak RPM below 16,5K why is it being used? And if this comment is vague in its interpetation then change it in the rule book.
I will comment on your quote below.
"It says just to note the changes in your sanction, and, or publicity.....It practically spells out, word for word, the APRA rules, no kidding ! Read it. Looks like APRA rules, have AMA's blessings already, minus the nine lap rule......"
Can you change the sanction for the NATS????
My point to all of this discussion was that I would like to see 424 run at the nats. And in order for that to happen we need to very clear on intent and wording of the rules for 424. It still sounds like everyone except the people who are running APRA are confused.
I have nothing against the TT 40, it is cheap and runs. I also understand that the rules are VAGUE enough that the 16,5K is pointless. All I ask is that we fix it so it is cut and dry.
As to EXPERTS flying 424, I don't think it should happen. Just my opinion. I like Dave's comments about splitting the trophies. Sounds like that is a good solution.
Dan
_____________________________
Dan Kane
(in reply to PylonWorld)
       Post #: 26
424 Unification - 8/8/2002 9:11:19 PM
MDP
Status: offline
Dan.....You are not missing anything. It only states ground RPM of 16,500, not peaked, or at least this is how the CD's interputed the rule. This RPM is a random check on the start line, ready for takeoff. This 16,500 number was not something APRA adopted at first. That was AMA. Most TT's will turn from 15,800 to low 17,000's peaked, and other engines on the list also, but of course no body launches at peak, mostly 500 / 800 back of peak, then the 16,500 number is no problem. I think this is not a good number to go by, because engines unload differently. Thats why APRA tested all engines with a flying prop, & unload prop. We found the Webra's, Rossi's, ABC Super Tigers, MVVS's, etc, blew the doors off the cheaper engines from the tests. The engines that made the list were K&B 4011's, ASP .40's, Super Tiger GS .40's, Thunder Tiger Pro .40's, OS FP .40's, and others. Over the test of time, the TT Pro .40 was found to be the fastest on the list, so thats the engine most everyone migrated to, with the Super Tiger GS .40, a close secound, so you see it not a single engine event. The TT Pro .40, was the one most wanted to use, because of performance.
AMA 422 rules are close to being workable, but it needs a little more work.
The way the rule book is worded for 424, I could see a Nelson / Jett .40, with a factory supplied canned muffler, backed off to 16,500. I have tested this setup, and A Nelson, with the mini pipe, out of the muffler, will turn the APC 9-6 over 19,000 RPM peaked......Do we need $350 engines, or engines that could turn over 19,000 RPM's peaked, and expert pilots lapping the entry pilots 3 or 4 times in 424 ??? I think not. See my point ? We desperatly need to get the 424 rules figured out with no loop holes. Until that day comes, APRA, NEPRO, etc, will be the successful races. This has already proven, by the test of time.
I would love to see 424 flown at the NATS, and I think Mike Condon could run 424, as long as it was according to the AMA rulebook, and he could run the APRA style provisional 424. Mike "can, & will" run the NATS however he see's fit, and that is his right ( thanks for the cart Mike ).......PS...What do we do with pilots that might be considered experts, that can't, or will not fly Nelson / Jett costs & speeds.....Shoot them ? Ask them to retire ? Buy them a Bass Boat, or a Girl friend ?.... APRA / 424 is a fun, & some times relaxing sport, that you don't have to get a loan, or have twenty year old reflexes, or all the extra time, to participate in.....Is it right to shut them out of this event.....Come on you guy's !....Speak up !...Am I the only one that gives a crap about you ? Maybe I'm wrong. I hope not.
       Post #: 27
424 Unification - 8/8/2002 10:49:36 PM
PylonWorld
Status: offline
MDP,
I think some new engines need to be tested and added to the master 424 engine list. Only two engines on the pre-2002 APRA engine list are still being manufactured. And the 2002 APRA engine list only has three engines on it. And one of those, the [URL=http://www2.towerhobbies.com/cgi-bin/wti0001p.pgm?Q=1&I=LXBUX5&P=0]Magnum XLS-40 BB ABC FSR[/URL], is questionable since it is a new version that is supposed to be improved. Magnum has been cloning the OS FX engines and coming out with new engines. The Magnum 32 is an exact clone of the OS 32 SX and the Magnum 36 is a bored out OS 32 SX clone.
I got a couple of TigerShark 40 engines and was going to send one out to Jimmy Allen for testing, however, it has a different size backplate, and I thought that would rule it out. But Kangke may do a backplate mount for it. So I'm going to run one today and see how they do. They retail for $57.77.
I think the current production Magnum, MDS, and OS engines should be tested. Perhaps a new officer in the NMPRA is warranted: Q-500 Sport Coordinator. This person could be responsible for testing of engines and other duties.
As a beginner, I wouldn't mind flying with the experts. I like Dave's input about awarding separate trophies (or places at least). The trick is figuring out how to score it properly. If I fly against two experts in a heat and come in third, I should get just as many points as someone who flies a heat against one expert and comes in second. You could use heat times and do it FAI style so that you are effectively competing against the clock, but still racing to win heats for pride and joy. That would seem very equitable.
Don Stegall
RCPRO Chairman of the Board
       Post #: 28
424 Unification - 8/8/2002 11:50:48 PM
MDP
Status: offline
Send Jimmy Allen & the APRA bunch an engine, and he will check it. He will eventually need to test several of the same engines, to make sure of the average RPM. The Super Tiger GS .40 & the Magnum Pro .40 were still available, last I checked. You might be right about the Magnum. Jim might want to check the XLS version, if he has not already. I would not delagate the job to anyone else. Jim & the guys have over ten years of experience doing this job, and are well aware of the needed changes. I ran the MDS, and, the TT Pro was stronger.
As for the Tiger Shark, the backplate has no effect on it's legality. Any backplate, beam, or stock mount is legal.
Remember there is, or was a retail dollar amount to consider ($100), plus a $100 claimer rule. A new ball bearinged OS FX, & other engines, were not allowed, because they were too expensive, and too powerful.
I would like to see experts fly with the Novices as long as there was a handicap enough to let the Novices be competetive, and have fun.
The APRA & NEPRO guys, have put many years of hard work, time & effort in their race rules, & events, and it shows by all their years of success........If you find a better mouse trap, congratulations !!.......But you have your work cut out for you !!
Too bad some you don't have much experience with these events. You would not be so quick to criticize, and try to re-invent the wheel.....
       Post #: 29
Re-inventing - 8/9/2002 12:08:43 AM
kane
Status: offline
MDP,
I am not reinventing the wheel I am only trying run 20" tires on 20" rims. NOT 21" tires on 20" rims. But wait maybe when I go to the west coast I will run 19" tires on my 20" rims.
HMMMMM,, the wheels are turning!
Dan
Dan Kane
       Post #: 30
424 Unification - 8/9/2002 12:29:04 AM
PylonWorld
Status: offline
MDP,
I don't want to re-invent the wheel, but if there is some way the whole country can benefit from the APRA experience, and we can formalize it, why not? Formalization would help bring order, and shouldn't reduce flexibility too much with the right formula.
I don't intend to sound critical. I'm trying to find a middle ground that is marketable to sponsors, and to newcomers.
Don Stegall
       Post #: 31
Formalized Already - 8/9/2002 12:35:34 AM
Bill Vargas
Status: offline
Its already Formalized,,, under AMA 424
BV
If it ain't leaking oil, then something's wrong,,, USMC, RETIRED!
       Post #: 32
424 Unification - 8/9/2002 12:55:14 AM
SSAN
Status: offline
This thread become very interesting and at the same time somewhat annoying regarding rules, engine and Expert Pilot's flying them. Well, let me get this straight guy's... But before I let it all out, let me tell you guys something about what we do here in Phoenix AZ for AMA 424/APRA.
Jim Allen is one of the greatest supporter for AMA 424 pilot's who are new to racing, and with that said, he has put tremendous efforts in helping out with us here in Phoenix. We all learned and benefits from competing against Jim in this class and with his help, has learned different tips in flying the race course. He guides us in how to set up the race planes and how we approach the Pylons. Not only just showing us how to FLY the course, but to RACE. With this said, I (we) learned many things by observing Jim and has incorporated the flying style to (ourselves) myself. So, for those of you who wants to help us improve, please do us Newbies a favor...
1. Stop whinning about RPM and engine because the people who
tested them know what the hell is going on. They approved
the listed qualified engines for a reason and for the purposes for all new pilots to choose them. Also, time change and technology change, so therefore, performance of the engine will change.
2. Some of you guys (Expert/Newbies) who stated that Expert Pilot's should not be flying them is full of it. How the hell are we new guys going to learn and be the best if we didn't compete against the best. If the Expert pilot beats the Newbies all the time, then the Newbies hasn't learned enough to be competitive. And if the Newbies **** and whine because of Expert pilots competing/beating them, then he's NOT a true racing enthusiast, and he will never move up to the next level of racing. A true racing heart will do what ever it take to be competitive and win. And by doing that, he must adapt and learn from the Expert hands on. Think of it, guys!!!
3. Last, but not least... Let the Expert fly against the Newbies so they can learn something. There's nothing likes hands on training. This way, the Newbies who graduated from AMA 424 will be more than equiped to run against the Expert in AMA 428 when he's there.
Listen... Because this Newbies is tired of the Politics and Bull *^%&*!!!
More power to you Jimmy Allen! We need you around to fly against. :-)
Sam S.
SAM-RAI... The Ultimate WOOD Q-500!
www.Sam-RaiRacing.com
       Post #: 33
424 Unification - 8/9/2002 1:01:05 AM
regis
Status: offline
[QUOTE]... [COLOR=red] capable [/COLOR] of turning a stock 9 x 6 APC propeller [COLOR=red]at over [/COLOR] 16,500 rpm on the ground. [/QUOTE] I do not think there is any misinterpretation of on the ground. Even if, while technically you might be able to measure in-flight rpms, nobody would want to go there. But which term - [COLOR=red] capable[/COLOR] or [COLOR=red]at over [/COLOR] - don't you understand? Come on guys, let’s stop the quibbling here. The TT 40 is more than [COLOR=red]capable[/COLOR] of turning a stock 9 x 6 APC propeller [COLOR=red]at over [/COLOR] 16,500 rpm on the ground. Are you the experts you claim to be - or not? Every one else knows what the TT 40 is [COLOR=red]capable[/COLOR] of . Why the stone wall? I am not here to suggest we blackball the TT 40. The TT 40 has all seven of the attributes listed by vector. I do not know what the answer should be. But I do know that if you raise the rpm limit, that will only exacerbate [COLOR=green]speed creep [/COLOR] .
As for experts flying 424; if the experts (428 flyers) did not also enter 424, I do not think PGRC would continue to hold 424 events. There is just not enough 424 only flyers. But, if/when 424 is flown at the nats (and possibly for regional championships too) 424 should be restricted (to non 428/422 entrants).
Regis 0o
       Post #: 34
424 at the NATS - 8/9/2002 1:52:25 AM
Pete Bergstrom
Status: offline
A little bit of research into the history of "Beginner - Novice" level events that are eventually allowed to run at the NATS will show that what eventually happens is that we end up having to invent yet another "Beginner - Novice" event. This was true from Navy Carrier in CL with "Profile Carrier", Slow Rat in CL Racing, 428 in Pylon Racing. (These are only three that come to mind off the top of my head!)
Originally the intent of Q500 was to allow the novice racer to learn to race and provide a fun event for experienced racers. Left alone, this is a laudable goal. When a National Championship is at stake, everyone enters and the entire event grows to the point that the original intent of "teaching new people to race" has been lost. Now 428 is an event that provides equal challenge and speed to what should arguably be our premier event, QM40 and draws the best pilots in the nation, expensive airframes, and expensive motors. No where would anyone have thought that Q500 would have gotten this far, and it never had until it became a "NATS" event.
By the look of the entries at this years NATS, the existing grass roots 424 programs are doing a great job of feeding pilots into the 428/422 racing program. I believe that 424 needs to be a grass roots event (see my post under "426 - Intermediate Q500?" and that is where it will do the best for us all overall. We don't need another event with "Speed Creep" - (what is that anyhow, this is racing!) nor do we want "Dollar creep" - or "run" - as the case may be. We will do nothing but chase away ptoential pilots and the cry for a "true" beginners event will come forth from the ranks once again! I have heard this before and I would like to stop from having to hear it again.
Regarding Racing Classes in General
There are only two ways to differentiate between events. Equipment or Pilot Skill. It is difficult to use them in combination because as soon as you move up a skilled pilot to the point that his wallet breaks, you have lost a racer totally. When the only difference between events is in equipment, then the pilots that love to race will figure out how to make the new equipment work just a little bit better and go have fun racing the new event in addition to their old event. The only true way to differentiate bewteen classes is by pilot skill with no restrictions on equipment other than the existing rules. This works well in the APRA with their 9 lap rules, etc. Then the improving pilot does not have to make a quantum leap in technology or expense to compete in the next class. He most likely already has the equipment or is in need of retiring worn out equipment.
Generally pilots move up in category through peer pressure. This can only be applied from the local racers that know the pilots in question. Once again, a grass roots function.
In conclusion I believe we should let each area promote its own grass roots racing program as their pilots. clubs, money and interest permits. This has been working better in the past few years and will take time to take hold. Remember, the existing situation did not happen overnight, but occured over a 7-10 year period. We need to allow ourselves the time to grow and mature at these events. Maybe we can get more clubs on the East coast if we are willing to put the work into the events we already have. We cannot legislate participation. Every time we try to do this we end up with lower participation.
       Post #: 35
424 Unification - 8/9/2002 2:01:27 AM
kane
Status: offline
It is starting to get ugly again!
From an expert pilot who is full of it. Adding to what Dave Norman posted, Let the experts fly in the heats. However, if they are "EXPERT" (what ever that means) they earn no points for the contest. After all they are only there to help the new guy, not to get a trophy or win or something silly like that.
Hats off to Jim Allen and anyone else that is doing a tremendous job!!!!!!!!!!!!!
I am not knocking anyone down for what they have done nor am I knocking them down for what they will do to promote racing.
I think the point is being missed. If you showed up to the Nats or any other contest with a TT 40 engine and I was the CD you would be disqualified. If I check it and it exceeds 16,5K on the ground. END of Story. If the engine is cabable regardless of how you set it isn't legal. It is my interpetation of the rule to check it on the pinch, (up to the CD to decide). Please correct me if I am wrong.
I am not a Politician, (however, I grew up in Chicago so it is in my blood), I have no idea what politics you are refering to, Sam??? As to the BS, if it wasn't for BS we wouldn't have anything to discuss at the races.
I too hate the fact that a discussion such as this one gets so heated. I guess we are all passionate about racing.
Dan Kane
       Post #: 36
424 Unification - 8/9/2002 4:18:36 AM
MDP
Status: offline
Don.....I didn't mean you were trying to reinvent the wheel, but some are, and they don't know it. Your interest is appreciated.
Regis.....Don't get all worked up over this 16,500 thing. It is just another loop hole in the rule book. The engines are tached on the line ready for the flag to be dropped. If an engine is taching too high, you will have to back it down or be disqualified. For the last 6 years I have been involved in this concept, not one starter has taken a tach, grabbed the contestants needle, peaked the engine to near melt down, reset the needle, & dropped the flag in time for the sixty secound clock. Thats not how it is done, and nobody complains. I am not saying thats the way it should be done, but for now, thats how it is......Now go to bed with NO SUPPER !!
Dan....I didn't mean you were trying to reinvent the wheel either. You have plenty of experience, and know whats good for 424. How every one has a different view of what the rule says, is the problem. Who's right & who's wrong? The rule wording needs to be simple, and all CD's need to apply it the same way........
< Message edited by MDP -- Aug 8 2002 11:39PM >
       Post #: 37
424 Unification - 8/9/2002 5:38:18 AM
SSAN
Status: offline
Dan,
Yes, the point is being missed. Here's why...
Sport Quickie or AMA 424 is an Entry Level Racing and are supposed to be a Breeding Ground for new racing pilots. To try and run this race at a National level was not the original intention of the person or organization that brought it up. And National is not a place for Newbies to be flying, especially if new pilots is all over the sky/place. It would be an embarrasement for Pylon Racing group indeed.
As for the engine... The engine was tested and approved and if one person want to change it then there must a votes by the majority or organization that approved it in the first place. It's not up to an individual to make personal change because of his/hers disapprove. That's why we have rules cycle.
Issues... I heard enough complains about this issues.There will always be someone that will bring up something negative to create issues among others or organization. A matter of facts, there was a complain about a Muffler being welded on instead of just screwing it on. What's the difference??? It's still the same engine with a welded Muffler. You see my point, Dan?
As a Newbies... I'm tired of hearing it and discouraged about these issues. Why can we just all keep it stupid, simple and fun?
Oh, sorry Mike... I guess I stoled your wordings! Must have a good reasons why...
Sam S
PS
My postind are not intended directly to anyone in particular,
just to let everyone knows that enough is enough about these
AMA 424/APRA engine issues.
