kingcobraRCU
GA, USA Status: offline
I DID IN FACT MAKE THE INTERCOOLER USING PART OF THE RADIATOR THAT CAME WITH THE CAMARO MODEL CAR KIT, SOME PLASTIC TUBING AND SHEET!!!! THE HOSES ARE INSULATION FROM AN 8MM SPARKPLUG WIRE!!! AND THE FRONT HOOD PINS ARE UNDER THE HOOD!!!! THE HOOD IS HELD ON WITH VELCRO!!! THIS BODY CAME FROM A NIKKO R/C CAR AND I SANDED ALL THE SEAMS, FILLED THE MOLDING ERRORS, REPAINTED IT CUT IT SO IT FIT MY YOKOMO, PAINTED THE INSIDE OF THE HEADLIGHT BUCKETS BLACK, CUT REAL METAL MESH FOR ALL THE VENTS, AND ADDED ALL THE LIGHTS MYSELF! AND YOU ARE REALLY STARTING TO GET ON MY LAST NERVE. YOU DON'T KNOW EVERYTHING YOU THINK YOU DO!
< Message edited by i8tweety -- 11/22/2004 3:05:44 AM >
