Tyler-RCU
IL, USA Status: offline
Hi guys, I purchased the OS1.60 and Jett muffler over a year ago to install in a 1/4 scale cap. I have since sold the plane and decided to try bolting the power plant combo onto my Dave Patrick Ultimate in hopes of gaining more power than my YS 1.20FZ has been providing. The YS is simply not enough to torque roll train with. Anyway, I started off with coolpower 15% fuel and a 20x8 prop. I think I was turning about 8600 rpm on the third tank of fuel on the ground. I ran the motor through the break in procedure as outlined in the manual. I then set the needles for optimum rpm (8600), and then richened the high end about 300 rpm slower. When I took off, the engine began coughing and loading up and died. The prop broke on an emergency, off field landing. I then tried an APC 16x8 and was turning 9,600 on the ground. I didn't fly this prop because I thought it would over speed in the air. I bought an 18x8-14 prop, but could only get it to spin up to 6200 rpm. I was afraid this would heat up the motor so decided not to fly with it. Yesterday, I tried a mejzlick carbon 18x6, but found the thrust to be low, take offs sluggish, and vertical suffering. I think I was getting about 9,300 rpm with this prop. The engine sounded like it was predetonating in the air, and it would loose power after about 1 minute in the air. When I tried to richen it up slightly, the engine would then begin surging in flight with lots of smoke, and appear to load up before dying. Four dead stick landings in a row. I then swapped out the OS #8 plug for an Enya #3 and found I could run the engine slightly richer, which did seem to smooth things out slightly and delay the overheating in the air. Off came the carbon prop, and on went an 18x6 wood prop. Thrust felt much better, slightly less rpm, and the plane flew much smoother, but the engine still predetonated and would loose power due to overheating. Three dead stick landings, then finally a decent flight with throttle management to prevent over-revving on the downlines. Today, I couldn't make it to the field to fly, but I switched from 15% coolpower to 5% Omega fuel. I tached the engine at 8450 on the ground. I tried a 20x6-10 prop, but could only get the prop to produce 5400 rpm. I spoke to another pilot on the other side of the country, and he informed me that there has been a tendency for the Jett muffler to cause the OS 1.60 to overheat in the air. This seems to be what I have been experiencing. I have spent a small fortune on props and fuel this past week. I would greatly appreciate some advice and feedback on the perfect fuel/plug/prop combination. I sure hope I can get this muffler to perform, because they ain't cheap! I have a demonstration show to perform on Oct. 12th, and I would like to have some time to get use to the new engine on this plane before flying in front of a large crowd of spectators. I am about ready to drop the reliable YS 1.20 back into and accept the lower power output. I look forward to hearing some ideas, Tyler
