RE: Free Extra 300 Plans    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> RE: Free Extra 300 Plans
Page: <<   < prev  5 6 7 8 9 10 [11] 12 13 14   next >   >>
Login
RE: Free Extra 300 Plans - 2/23/2006 6:07 PM
buckiflyer
Score: 100
Last Login: 1/9/2008
Status: offline
buckiflyer was here
bucki
Build'em and fly'm~ bucki's my name~Katana's my game
Hide Signatures
(in reply to STomic)
       Post #: 251
RE: Free Extra 300 Plans - 2/24/2006 11:11 PM
tucker1865
Score: 100
Last Login: 3/4/2013
Status: offline
Silver Eagle.....got em...thanks a bunch. Dave
< Message edited by tucker1865 -- 2/24/2006 11:12 PM >
Hide Signatures
(in reply to buckiflyer)
       Post #: 252
RE: Free Extra 300 Plans - 2/27/2006 7:01 PM
buz2au
Score: 100
Last Login: 6/2/2013
Status: offline
OK finally got to go to the hobby shop, & what a let down, even though I rang to make sure they had landing gear & canopy large enough for the Extra & a full colour range of monokote, I wanted maroon & cream, saddle up & move out for the 1¼ hour trip to town.
It turned out that their extra large landing gear & canopy would have been big enough for a 40 plane if you were lucky, & their full range of monokote turned out to be 6 colours from the solarfilm range.
Not wanting to totally waste the trip, my colour scheme will now be red, dark yellow & white, with black trim.
Won’t be going back to that hobby shop real soon, got to find a good reliable mail order place.
So I started to cover the tail feathers (white & dark yellow), this is my first time using film of any kind, I’m a old silkpaper & dope man, it’s not looking too bad, only a few small wrinkles, would help if I had some proper heating irons & gun instead of the clothes iron & wife’s hair dryer.
As I get a bit more done I’ll post some pics
Hide Signatures
(in reply to tucker1865)
       Post #: 253
RE: Free Extra 300 Plans - 3/3/2006 6:00 AM
buz2au
Score: 100
Status: offline
Here are a few pics of my cover job so far, be kind it's the first time I've used film covering & I know I've done a crappy job of it.
Still need to put a black pin stripes over the colour changes & to hide film overlaps.
If it look real bad I may redo it after a few test flights (if I haven't thrown it in to the ground by then)
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to buz2au)
       Post #: 254
RE: Free Extra 300 Plans - 3/6/2006 11:59 AM
CARTERrc
Score: 100
Last Login: 2/6/2010
Status: offline
G'day
I have the 60 size set of plans on my computer and want to know what size paper to print it out on. Can any one help please.
Hide Signatures
       Post #: 255
RE: Free Extra 300 Plans - 3/6/2006 12:31 PM
buz2au
Score: 100
Status: offline
G'day CARTERrc,
I just printed mine on A3 sheets & taped them together, or you could take them to a plan printing company & get them to run it off on continuous feed paper but be prepared to pay many $'s for them, check with silvereagle he may be able to supply printed plans cheaper than you could get them done here.
Hide Signatures
(in reply to CARTERrc)
       Post #: 256
RE: Free Extra 300 Plans - 3/6/2006 6:16 PM
highfly3D
Score: 100
Last Login: 6/14/2013
Status: offline
Hello Buzz
What engine are you gona use for the extra and what type of servos are you using., your extra looks good.
Highfly3D.
_____________________________
I will say it only once Yak 54 the best aerobatic plane ever made.
Hide Signatures
       Post #: 257
RE: Free Extra 300 Plans - 3/6/2006 6:27 PM
buz2au
Score: 100
Status: offline
G'day highfly3d,
Most likely a super tiger 61 or 75 & just standard JR servos & see how they go
Hide Signatures
(in reply to highfly3D)
       Post #: 258
RE: Free Extra 300 Plans - 3/9/2006 1:02 PM
CARTERrc
Score: 100
Status: offline
G'day
I have finally got my plans for this plane printed out took 2 A0 size paper just for the wing sheet . Now I have a question with the leading edge. The plans say to have a sub leading edge then a thin balsa rod in front of that then shape that rod to the shape required. My Question is is it possible to get the right size leading edge already shaped and be done with the shaping and the subleading edge?
Hide Signatures
       Post #: 259
RE: Free Extra 300 Plans - 3/9/2006 1:25 PM
buz2au
Score: 100
Status: offline
G'day CARTERrc, answer no, the leading edge has a taper to it from root to tip. What I did was to build the wing up using the sub-leading, then fixing the leading edge (which I cut over size) to the wing, then the top & bottom 1/16" cover sheets & used their curves to shape the leading edge with a razor plane & sand paper, the trick was to glue several grits of sandpaper to 12" long 1"x2" pine, it shapes up real quick & easy, it's not a major pain to do if you take care & some time
Hide Signatures
       Post #: 260
RE: Free Extra 300 Plans - 3/10/2006 3:31 AM
CARTERrc
Score: 100
Status: offline
G'day Buz
Thankyou for the reply, but what if the leading edge was the right size for the biggest rib and then I just sand it ti the right shape for the smaller rib?
Hide Signatures
       Post #: 261
RE: Free Extra 300 Plans - 3/10/2006 6:04 AM
buz2au
Score: 100
Status: offline
G'day Carter
A couple of points
1. The LE stock would have to be 7/8"x1/4" - may not be a size you could get
2. Fit - LE radius to match wing shape
3. Would require about the same amount of work to get it to the required shape
4. Cost
You would be surprised how easy it is to do compared to building up & shaping the cowl
Hide Signatures
       Post #: 262
RE: Free Extra 300 Plans - 3/10/2006 11:58 AM
CARTERrc
Score: 100
Status: offline
G'day Buz
Thankyou very much for clearing that up for me. I will do it by the plans and TAKE MY TIME!!!!. One more question could you please tell me the dimensions of the leading edge and sub leading edge in metric mms please. I am only 15 and don't know the conversions yet! Thanks for all of your help, I'll get building right away tomorrow.
Hide Signatures
       Post #: 263
RE: Free Extra 300 Plans - 3/10/2006 1:23 PM
buz2au
Score: 100
Status: offline
G'day Carter
25.4mm to the inch so just multiply by the fraction ie 7/8" = 25.4/8x7 = 22mm appox, toy will find that the common sizes will round up/down to 0.5mm
But just cut it from a sheet of 3/8" (9.5mm) to fit the sub LE with a 5-10mm over hang (at least) remember that 1.5mm of the 5mm will be taken up by the 1/16" ( 1.5mm) cover sheet on each side
Hide Signatures
       Post #: 264
RE: Free Extra 300 Plans - 3/31/2006 12:55 PM
CARTERrc
Score: 100
Status: offline
G'day
After 4 solid days of working I have finally got the wing complete. As this is my first build I do not know the secrets, but thi wing looks right and what I am happy about is that there are no dips in the front sheet just behind the leading edge. If I get around to it I will post some pics!!!!!!!!
Hide Signatures
       Post #: 265
RE: Free Extra 300 Plans - 4/3/2006 8:56 PM
highfly3D
Score: 100
Status: offline
buz2au
Post some pics its been long time, you have not posted your pics of the model.
Highfly3d.
Hide Signatures
       Post #: 266
RE: Free Extra 300 Plans - 4/6/2006 12:23 AM
universe
Score: 100
Last Login: 3/31/2007
Status: offline
Were are the plans for the 60 size extra I cant find them Thanks
Hide Signatures
       Post #: 267
RE: Free Extra 300 Plans - 4/6/2006 5:26 AM
buz2au
Score: 100
Status: offline
highfly3d, the build is on hold at the moment due work commitments, hope to get a chance to do a bit more over Easter.
universe, go to scratch builder.com & follow the plan request post, supply the requested details & the plans will be emailed to you.
http://www.phpbbforfree.com/forums/scratchbuldersc.html
Hide Signatures
(in reply to universe)
       Post #: 268
RE: Free Extra 300 Plans - 4/6/2006 4:59 PM
universe
Score: 100
Status: offline
Thanks for the help is there gonna be any Yak plans sometime?
Hide Signatures
       Post #: 269
RE: Free Extra 300 Plans - 4/8/2006 1:43 AM
tucker1865
Score: 100
Status: offline
I have the plans but cannot open them...Do I need a CAD program and if so will AutoCad LT 2000 work. Thanks
Hide Signatures
       Post #: 270
RE: Free Extra 300 Plans - 9/2/2006 9:59 AM
scolpit
Score: 100
Last Login: 4/1/2009
Status: offline
Can anyone send me the Extra 300 80" plans? Email: sketansy@hotmail.com
Thanks.
Hide Signatures
       Post #: 271
RE: Free Extra 300 Plans - 9/2/2006 6:18 PM
olof
Score: 100
Last Login: 4/6/2010
Status: offline
I dont think the 80" extra plans ever got finished unless I missed them, Ive been after this size extra plans for ages, if any body out their knows about them or any others please post.
thanks
Before Oblivion
Hide Signatures
(in reply to scolpit)
       Post #: 272
RE: Free Extra 300 Plans - 9/2/2006 8:03 PM
RVM
Score: 100
Last Login: 3/30/2012
Status: offline
The site to request plans is down.
There is no substitution for human competition.
Hide Signatures
(in reply to olof)
       Post #: 273
RE: Free Extra 300 Plans - 9/5/2006 8:51 PM
mmattockx
Score: 100
Status: offline
quote:
ORIGINAL: RVM
SilverEagle was having problems with the site and shut it down. He is currently out of action with family stuff and is not reachable by PM or e-mail as well.
On the plus side, I have those plans and can e-mail you a copy if you PM me an address...
Mark
Waco Brotherhood #4
Hide Signatures
(in reply to RVM)
       Post #: 274
RE: Free Extra 300 Plans - 9/6/2006 1:50 AM
blindguarden
Score: 100
Last Login: 4/4/2008
Status: offline
I have had the same problem and have been trying to get someone to e-mail me a copy of them for a few months now but to no availe .
AMA # 825237
Hide Signatures
(in reply to RVM)
       Post #: 275
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.953RCU1
