hookemut
TX, USA Status: offline
quote:
ORIGINAL: iamtom Hello all, I finished my Chippy the other day and flew it that night. All went well. Just a little over proped with a YS 1.20 and a 17X6 APC. Going to try a 16X6 instead. On thing I did in anticipation of the dred balance problem was to replace the Elv. push rods,which weigh about 3 oz., with .098 carbon rods which weigh about 1/3rd of an oz. I used ,at the elv., a GP 4X40 threaded coupling and clevis. The other end I used a piece of brass tubing flattened to an oblong shape as to hold the 2 carbon rods and a piece of 3X32 wire in between them. All components held together with the black rubberized C/A glue. Use a solder link at the servo and should work very well. Mine weighed out at 13 1/4 lb's. I had to place the 1700 mah nicad pack behind the c/g to balance. I was shocked after all the stories. My plane flew very well and straight with only a couple of clicks of up elv. Good luck, Tom Hi Tom, Well done-on both your finished Chipmunk and the follow-up message! You mention placing the 1700mah battery behind (aft?) of the cg? I, too, find the various doom-and gloom stories hard to comprehend. For years I have found Dick Pettit's reports to be factual and honest-your Chipmunk experience bears out his assessment. Meanwhile, I'm plugging along, at my usual slow pace. Pin hinges except for CA hinges for the flaps. I just purchased a JR 7202 and will set it up for the Chipmunk as well as my other six active models. great hobby!! hookem
