RE: New 81" GP Super Chipmunk
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Super Chipmunk
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> ARF or RTF >> RE: New 81" GP Super Chipmunk
    Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
    Login
    RE: New 81" GP Super Chipmunk - 11/21/2004 2:17:18 AM
    Capt G
    Status: offline
    Sure you could mount it inverted. To minimize cutting the bottom of the front all up - a shaft extension (if such a thing exists) would be advisable to keep the engine as far back as possible. Of course you remember that the prototype also used a ton of lead in the nose for balance so you know what moving the engine back will do.
    (in reply to jimmyjoe)
           Post #: 76
    RE: New 81" GP Super Chipmunk - 11/21/2004 2:42:49 AM
    jimmyjoe
    Status: offline
    exactly!! However, how much weight have you had to add to yours?
    (in reply to Capt G)
           Post #: 77
    RE: New 81" GP Super Chipmunk - 11/21/2004 6:33:56 AM
    PlaneKrazee
    Status: offline
    The Enya and Laser four strokes have the push rods and valve covers in the rear giving more clearance. The Enya comes with the prop driver tapped to accept the provided pins to lock in a spinner back plate. With this engine a small aluminum disk can be used to extend the prop out with little trouble. A 8x1mm thread Higley heavy hub will counter any CG changes.
    Looks like a G26 will also fit completely in the cowl minus the plug with a 1/4-3/8" longer custom prop driver. I hope to find out this coming week.
    _____________________________
    KB1DTB
    AMA11123
           Post #: 78
    RE: New 81" GP Super Chipmunk - 11/21/2004 2:01:38 PM
    flynut007
    Status: offline
    Capt G......cowl looks good!!!....did a good job cutting it out for the YS-I will be mounting mine like that as well.
    (in reply to PlaneKrazee)
           Post #: 79
    RE: New 81" GP Super Chipmunk - 11/21/2004 11:25:57 PM
    Capt G
    Status: offline
    Today it was raining (no flying) so we got the ailerons and flaps mounted, linkages made and working. Check out the scale tabs on the ends of the ailerons!
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    < Message edited by Capt G -- 11/21/2004 11:33:17 PM >
    (in reply to flynut007)
           Post #: 80
    RE: New 81" GP Super Chipmunk - 11/22/2004 3:22:10 AM
    tIANci
    Status: offline
    Capt - she is lovely! Beautiful ... sigh ... now to find out how much it will cost in Malaysia. They usually sell them here for almost twice the price in the US, GP prices here totally sucks.
    Anyone thought of using the RCV 120 SP to keep their plane cowling looking nice? Its geared and can throw a big prop.
    Its nice to be important, but its more important to be nice ...
    www.rcheadz.com
           Post #: 81
    RE: New 81" GP Super Chipmunk - 11/22/2004 3:39:55 AM
    gunny11
    Status: offline
    Picked up mine today. WOW! Again, Great Planes has done another fine job. There gooood!
    I was doing a little searching and an OS 160 four stroke would really be nice. Both cylinders would stick out 1/4". But still contemplating on a gas yw 24, RCS 140.
    gunny
    (in reply to tIANci)
           Post #: 82
    RE: New 81" GP Super Chipmunk - 11/22/2004 4:22:25 PM
    Capt G
    Status: offline
    A twin would be really nice in this plane. I had a 1.40 sitting on the shelf so that made my decision for me.
    (in reply to gunny11)
           Post #: 83
    RE: New 81" GP Super Chipmunk - 11/22/2004 4:37:38 PM
    PlaneKrazee
    Status: offline
    I have a 160 twin and as you say both valve covers will protrude. If it fit without cutting it would have gone in, it may in the future anyway. I think the carb would have to stick thru too. I am not sure you can get the cowl over the engine even with the valve covers removed.
    I wanted to keep the engine concealed but in reality it is not going to win in a scale competition so it really doesn't matter.
    KB1DTB
    AMA11123
           Post #: 84
    RE: New 81" GP Super Chipmunk - 11/23/2004 12:29:26 AM
    gunny11
    Status: offline
    Yes, either the cowl gets wider or the top half of the cowl gets removable.
    Is anyone installing a YW 24 or RCS 140 GAS?
    Gunny
           Post #: 85
    RE: New 81" GP Super Chipmunk - 11/23/2004 12:36:13 AM
    Capt G
    Status: offline
    More rain today! So the wing is now done. Fitting only needed a little sanding for a good fit. I did find the first problem area in the mounting of the wheel pants. The method used does not give good support and the pants flop around loosley. My fix was to install a bracket to clamp the wheel pant to the gear strut. Nice and solid now. (strut fairings not yet installed). The wing weighs 4 LBs. - total so far is 10LBs.
    Click for fullsize
    Click for fullsize
    < Message edited by Capt G -- 11/23/2004 12:40:22 AM >
           Post #: 86
    RE: New 81" GP Super Chipmunk - 11/23/2004 2:25:21 AM
    PlaneKrazee
    Status: offline
    All I have done so far is the ca hinges, trimming the canopy, cockpit and decals. I used Radio South 1/4 scale hinges. I hope to have the wings completed tomorrow. I'm a little slow right now.
    Capt G,
    What are you using for servos?
    KB1DTB
    AMA11123
           Post #: 87
    RE: New 81" GP Super Chipmunk - 11/23/2004 10:41:27 AM
    Capt G
    Status: offline
    Servos are Expert (JR) 571s (65oz) for the ailerons, flaps and elevators, 2721 (119oz) for the rudder and a std bb servo for the throttle. An interesting observation re. the wheel pants is that there is a picture on the side of the box showing nylon straps securing the pants to the strut, An idea that did not make it into the instruction book!
           Post #: 88
    RE: New 81" GP Super Chipmunk - 11/23/2004 3:25:35 PM
    PlaneKrazee
    Status: offline
    I thought I saw straps somewhere. It makes sense since why would you install the wood back up plates without installing straps and screws. They may have rushed the planes along to get them out for christmas and missed some of the details in the manual.
    Are the formers in your fuselage pronounced? I figure the decals will distract from them. Too bad they didn't install them on the panel lines.
    KB1DTB
    AMA11123
