Double Vision
Tower Hobbies
Logged in as Guest
  Printable Version
Carden 35% Extra 260 - RTF
Seller:  jmiracle
Details:   $2,950.00   |  10/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> TEAM RCU >> TEAM RCU - Chip Hyde! >> Double Vision
Page: [1]
Login
Double Vision - 10/4/2004 10:12:34 PM
zeke-RCU
Status: offline
I flew the DV for the first time on Sunday, October 3, 2004 and I have to say it was real pleasure flying the Double Vision. The DA 50 R is nothing less than a powerhouse just waiting to be opened up. I did have glue the elevators on to the fusuluge. The sufaces just moved around to much. Do not plan on taking it apart. Looks good sitting accross my 2004 Ford Explorer Sport Trak bed.
I do plan on installing a smoker it the plan this winter. Mr. Hyde, excellent flying machine. I do wish you would work harder on part repplacements(bearing) and that you will give the information so that the DV can be flow on the AreoFly Professional ASAP.
People need to stop worry about the weight and fly the beast!
thor3101@hotmail.com
       Post #: 1
RE: Double Vision - 12/8/2006 4:21:57 AM
ddavis
Status: offline
Chip; I have a Brison 4.2, could it be used with sucess on the DV ? I saw one fly with a ZDZ 60 and it flew well.
(in reply to zeke-RCU)
       Post #: 2
RE: Double Vision - 1/2/2007 2:45:54 AM
ddavis
Status: offline
Hi Chip, still waiting on a reply on wheather a Brison 4.2 could be used with sucess on the DV
(in reply to ddavis)
       Post #: 3
RE: Double Vision - 1/11/2007 3:42:44 AM
toddblose
Status: offline
what is the weight of the Brison 4.2?
_____________________________
http://toddblose.homestead.com
Team Futaba,FlightPower,Hacker,CA Models,Hobbico, PowerMaster,HydeMounts,ModelGlasses
       Post #: 4
RE: Double Vision - 1/12/2007 3:23:46 AM
ddavis
Status: offline
Brison 4.2 weighs 5 lbs. and 34 lbs thrust. Thanks for your consideration. ddavis
(in reply to toddblose)
       Post #: 5
RE: Double Vision - 1/12/2007 9:55:50 PM
toddblose
Status: offline
It should not be a problem, we are flying the Double Vision with a Kroma 50, Da 50, an a BME 50
just use the throttle wisely
       Post #: 6
RE: Double Vision - 1/12/2007 11:57:32 PM
Maudib
Status: offline
The only issues would be that the cowl is REALLY gonna get eat up due to the side mount carb and larger engine... probably would just have to leave it off actually
The rear induction models are tidier... and even then need some relief for the muffler (or header) and cylinder head...
I think at 5 lbs + you are really adding alot of weight to the plane... yes the engine can pull it... but the wingloading (that is SO awesome with a strong 50) will be diminshed...
Mine's a little over 17 lbs with care taken not to weigh it down...
They quote e Brison as 4.75 lbs... and that may not include the muffler and ignition... The DA50 is 3.75 lbs all up... SO I'm guessing you'd add 1.5 lbs to the weight. You'll tote a larger prop too (more weight) and more fuel as well probably.
Ley's just say that the plane is so sweet... that I would sooner consider selling/trading the Brison for a better match than to stick with it...
       Post #: 7
RE: Double Vision - 2/20/2007 2:20:38 AM
rcflyerdave
Status: offline
I have just ordered a DV.I have aZDZ 40,ZDZ60,and Saito 180(loves fuel).Which engine would be better.I am leaning toward the 60.I love lots of pull out from low hangs.Any mods recommended.
Dave(www.rcflyerdave@hotmail.com)
       Post #: 8
RE: Double Vision - 2/20/2007 3:18:08 AM
Maudib
Status: offline
It's the only one of the 3 that will fly it well (darn well actually)...
Keep the rest light and you'll love it...
(in reply to rcflyerdave)
       Post #: 9
RE: Double Vision - 2/21/2007 1:26:59 AM
rcflyerdave
Status: offline
Thanks for the reply.Any pics or hints.Also do you go to Walley's Flyin in Summersville,WV?About 2 hrs from you.Im in SW,Va.
Again thanks, Dave
(in reply to Maudib)
       Post #: 10
RE: Double Vision - 2/21/2007 2:18:49 AM
Maudib
Status: offline
Yu can check out the other DV thread... it has some info there...
Be careful about the cabanes orientation and aldo do NOT do the horizontal stab mod the manusl talks about... it was for older revisions.
http://www.rcuniverse.com/forum/m_1587236/mpage_1/key_/tm.htm
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
Photo Gallery | Member Video Posts |
