RC Car Radio control lost!
Tower Hobbies
Logged in as Guest
  Printable Version
JR R2000, JRPR2000 10CH RX, and JR Synth TX Module
Seller:  Erick Royer
Details:   $400.00   |  9/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> RC Car Radio control lost!
Page: [1]
Login
RC Car Radio control lost! - 8/8/2002 9:23:29 PM
Norris White
Status: offline
I have little radio control over my rc truck as of yesterday. With radio on the controls are at best jerky up to 10 ' range and nothing past that. It acts like interference, but I have run in this area for months with no problems and I have the same results at another location a mile away and 24 hrs. later.
I have changed batteries and check all connections and looked for frayed or broken wires.
I also switched the 27.045MHz crystal with another cars 64MHz crystal and that didn't work at all in either car.
Do I have a bad crystal, and why didn't the 64MHz one work, are they too far apart in frequency????
Sorry for the newbie question.
       Post #: 1
RC Car Radio control lost! - 8/9/2002 12:13:14 AM
MikeMayberry
Status: offline
You can't switch from 27mhz to 75mhz by changing the crystal.
Mike.
(in reply to Norris White)
       Post #: 2
Thanks Mike.......... - 8/9/2002 2:19:57 AM
Norris White
Status: offline
But, do you think I have a bad 27 crystal??
       Post #: 3
RC Car Radio control lost! - 8/9/2002 3:50:59 AM
MikeMayberry
Status: offline
It's possible but there are many things that can cause glitching or poor range.
Is this an electric or nitro car?
Mike.
       Post #: 4
........... - 8/9/2002 4:16:45 AM
Norris White
Status: offline
Nitro, so what should I check that I haven't checked.
Lack of range....I'm talking 10 feet with the antenna pointed at the car and even then the servo's are jerking.
So can I get different frequency crystals for this radio if I stay in the 27MHz range, so when I do have interference and can switch them?
Thanks Mike.
       Post #: 5
RC Car Radio control lost! - 8/14/2002 3:54:37 AM
MikeMayberry
Status: offline
What radio system and receiver do you have? What crystals are you using? If you are still having problems I would sent it in and we will check it out for you.
Mike.
       Post #: 6
Mike,thanks for the help....... - 8/14/2002 4:16:47 AM
Norris White
Status: offline
But turned out to be a newbie problem, the new batteries I installed in the car turned out to have one bad one in the batch, didn't believe it until I stuck a ohm meter on it them. Simple solution to a newbie problem, next time I will look hareder at the batteries instead of just putting in new ones.
Thanks again.
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.455RCU1
