RE: Snowmobile Hop ups?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Unusual R/C >> RE: Snowmobile Hop ups?
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: Snowmobile Hop ups? - 1/30/2005 2:46:03 PM
derric
Status: offline
my pionion gear doesn't have the little screw in it to take it off but i imagine that i can still take it off... i might ruin the old motor though so i would need a new and better one.
(in reply to derric)
       Post #: 26
RE: Snowmobile Hop ups? - 1/30/2005 7:52:57 PM
huttcraft
Status: offline
Hey MNKay,
I'm the opposite -- all my experience is with nitro, not electric, and with boats rather than cars or snowmobiles. Your set-up looks great. Did you build your tranny from a widely available gear set or are the gear wheels and clutch custom made? Did you have to do anything to keep snow out of the carb? Will the suspension and track be easy to upgrade so you can start opening'er up more often?
I'm jealous.
Dave
(in reply to mnkay)
       Post #: 27
RE: Snowmobile Hop ups? - 1/31/2005 2:39:06 AM
mnkay
Status: offline
Hey Dave,
Don't be jealous. Make your own. It took me 3 days to plan and 5 days to assemble. 5 more days of tweaking and here I am. As for the tranny, it is difficult at first, but when you make one, the second and third are easier. The original !QUOT!hex!QUOT! gear that came with the ski doo is being used as the tunnel drive system. I purchased a middle gear !QUOT!center drive!QUOT! system for a T-maxx and purchased the shaft for that gear. I am using an 18 tooth clutch bell and cannot go any smaller for the center drive shaft will rub on the clutch bell. I have a air filter that covers the carb so snow is not a factor. Also if you look at my setup, the windshield provides a buffer zone from the ground or snow. The rear suspension and track are all stock. I have not done a thing to it. It works and works very well. Again start hitting jumps at 20mph and forget this setup. A custom track system will have to be built out of light steel. I have designed and built a system but yet to install it. The ski doo is a handful to control at higher speeds. I let her rip today but only reached 20mph. The snow is soft and slushy and slowed me down quite a bit.
I would like to hit higher speeds but handling those speeds with the stock steering is a challenge. Today I installed a front end Strut tower brace and secured the mock front end stabilizers in front of the shocks extending underneath the belly pan. I secured a screw right through so skis do not flop from side to side. I will be tightening up my steering a little more and see how it runs tomorrow. I ran it today with the strut brace and ran more straight than previously and did not lean as much. It definitely tightened it up. Still under full throttle the rear end spins and constant steering correction is needed.
Overall I am very happy with the results. I did not have to purchase a Art attack to enjoy the snow and I hate snow. I am waiting for it to snow so I can run it down the street full throttle. I have however rolled it about 10 times and in 1 incident 1 rolled it 3 times and it landed upright and drove away. I have had it upside down and never stalled or over revved the engine. It is very durable as long as you build your chassis strong.
A friend of mine and I are now designing and should be ready soon a Nitro Belt Drive System. It is still being worked on but if it works, pretty well anybody could setup a nitro on a ski doo. It is much easier to make than the tranny I have designed. We will test with a .21 engine. It is powerful and will be the true test. I am hoping for belt longevity to be in around the range of 15-25 tanks of gas or 150-250 minutes. In nitro age, that is pretty long. Considering the ease of assembly would be feasible as long as belts are available. I will keep you posted. Check out the new Pictures.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to huttcraft)
       Post #: 28
RE: Snowmobile Hop ups? - 1/31/2005 3:07:08 AM
j.d.roost
Status: offline
Hey all. I just got one off Ebay (it's not here yet). Its going straight to nitro ( I have a few pull start .15's sitting around and a TON of old tmax and 1/8 scale parts).I have a few questions.Is the stock drive gear on the right or left side (driver or passenger if it were a car)?Also will the fuel tank and rx battery fit under the rear seat?
Thanks, cant wait to get mine.
< Message edited by j.d.roost -- 1/31/2005 5:27:13 PM >
(in reply to mnkay)
       Post #: 29
RE: Snowmobile Hop ups? - 2/5/2005 6:06:29 PM
huttcraft
Status: offline
That's a fantastic looking setup MNKay. I hope you'll post some pics of your clutch/belt system when it's done -- sounds much more faithful to the real thing.
I wonder if you'd have any steering improvement with some light pneumatic shocks on the front of the skis, as in full-scale machines, keeping the skis in contact with the snow all the time. Also, have you put some ballast over the track? I see you're using a small fuel tank under the shroud -- is that a hopper fed by a larger tank under the seat? With nitro boats I usually use an 8 oz tank feeding a 1 or 2 oz. tank, which feeds the carb. The pressure tap on the exhaust goes to the 8 oz tank. That way until you're almost out of fuel you have no air in the tank feeding the carb, so the engine is much more reliable. Not that it sounds like you're having any trouble with the engine, but a setup like that would allow you to put some weight over the track.
I think for now I'll ride your coat tails and let you invent the perfect belt drive, then either buy one from you or get your advice to do it myself. Then we can organize the pan-Canadian rc snowcross challenge..!
Dave
< Message edited by huttcraft -- 2/5/2005 6:07:27 PM >
(in reply to mnkay)
       Post #: 30
RE: Snowmobile Hop ups? - 2/9/2005 7:17:13 PM
Seba.p
Status: offline
Hi !! and sorry I AM VERY BAD IN ENGLISH... Btw someone have video?? About New Bright 28 ...
       Post #: 31
RE: Snowmobile Hop ups? - 2/12/2005 7:17:10 PM
wayneheim
Status: offline
I just got One of these Ski Doo's. Very cool but way too slow. Saw mnkay's post about an inexpensive replacement motor. Kind of new to this. Looking for an easy solution to get a bit more juice to this thing. Can anyone else tell me what kind of engine to get and where to find it. I not worried about pulling the old motor or soldering in a new one... i can do that... but some of the posts call for replacing all the electronic, etc. and that is a bit out of my league.
Any help would be greatly appreciated.
Wayne
(in reply to mnkay)
       Post #: 32
RE: Snowmobile Hop ups? - 3/1/2005 2:42:27 AM
Hobbysect
Status: offline
Here is my question after reading all of this, what is the pitch of the or the pinions used. I have for the past couple of nights been modifing mine and today I have ran into this post. I have stripped all electronics out of it and replaced it with some laying around parts. I have a modified Peak Raceing motor, Novak Hammer ESC, and a Pro Racing Servo installed and working very will in my snowmobile. I have added a 15 tooth pinion but I would like it to go faster. I got this motor pinion off of an old Radio Shack Radio Controlled vehicle I have dismembers for parts and drilled the center mounting hole so that I can press it on the Peak Racing motor armature. I have done a search for motor pinions on Towerhobbies.com and found some that are 32 pitch. Will these work? I will also be adding some little weights to the belly pans outest most points so that it wont tip as easyly in turns. Since I have replaced the original 9 tooth with this 15 tooth it goes a little faster. I like the shock idea and also mounting the motor to the front instead of on top. I had actually broke the upper portion on the gear box when I was modding the area for the motor and had to make a motor plate. This was actually a good thing in my eyes. But back to the question at hand. -----Tony
_____________________________
Kyosho Mini-Z: Blue Viper 95 BLUE TO THE CORE, also Purple Mustang Cobra 93, Internal Turbo and Antenna
Team Losi XXX-S
(in reply to wayneheim)
       Post #: 33
RE: Snowmobile Hop ups? - 3/21/2005 2:09:58 AM
bw27
Status: offline
This is a 1/8 scale Polaris. I cleaned out the tub and installed a 540 motor w/ 15t 32p pinion. Standard radio gear, Novak Explorer. Battery just barely fits under seat. Much faster than stock. Some belt slip in heavy snow. Not much time on it yet, still some issues to workout. Fun to build.
Thanks Brian
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to bw27)
       Post #: 34
RE: Snowmobile Hop ups? - 3/21/2005 8:47:25 PM
niceorange
Status: offline
Hello all, sorry I haven't been on in forever to reply to some of the questions.
MNKay... crazy setup, but I wouldn't touch it! Nitro is fun, but decent electric parts can match it for performance and be much more reliable. I can see how that tranny would be problematic. Mine is tough enough to line up well wit a flexible belt, never mind trying to align and mesh gears and a vibrating .12. That said, nice job thinking outside the box.
In terms of my gearing, I run a 12 tooth pinion into my gear box, which yield a lowering ratio of 3.8:1. The belt pinion pulley is 16 teeth, the spur pulley 39.
After my original post I made some other modifications. I reinforced the motor mount and tunnel with angled brackets. I also installed some bearings to better support the drive axle. I bought two oil filled shocks for a Duratrax Evader ST. I removed all the plastic links that restricted rear suspension travel, and it works great now. I rewired my motor, ESC, and everything else with Deans Ultra plugs, and bought 2 GP3300 batteries.
With the GPs, the LRP runner reverse plus, and the 16 turn Trinity Speedworks, the power is close to being to much for the transmission setup. I snapped my original belt (it had been pretty well abused), and now have a hard time keeping the spur gear assemble tight on the drive axel. Under heavy load it likes to spin and slide away from the tunnel. When that happens, the assemble starts hitting the belly pan and shreds the plastic pretty good. No big deal, but something I'm working on for next year. What I really want to find is a better way to mount the spur pulley to the drive axle. The spur pinion is very well supported, but the spur pulley is so-so, especially under the power I'm giving it. I was thinking about maybe taking the drive exle to a machine shop and having a pully mount made. We'll see what I think up.
Overall, this sled is fun as hell to drive. It goes well in a couple inches of snow. It's best suited for flat areas, but it will climb a bit if the snow is packed and it has some speed. It jumps great as long as you hit the jump straight and are prepared to steer into the lean as it comes down. Keeping it upright is a skill that you aquire once you get used to predicting it's movement. For the most part though, it works great, and people love it. It's pretty damn cool!
Kevin
(in reply to bw27)
       Post #: 35
RE: Snowmobile Hop ups? - 3/30/2005 12:14:00 AM
IBrakeForNobody
Status: offline
Hey,
Sorry to bring this thread back up but here is my 1:8 Blade Striker X.
Once I get the new electronics for my Rusty, all the old ones (including a Monster stock motor) are going in there.
Answer truthfully or don't answer at all.
(in reply to niceorange)
       Post #: 36
RE: Snowmobile Hop ups? - 3/30/2005 1:54:17 AM
experimental_pilot
Status: offline
Are you going to post the video here?
       Post #: 37
RE: Snowmobile Hop ups? - 10/26/2005 4:23:05 PM
