niceorange
MA, USA Status: offline
Hello all, sorry I haven't been on in forever to reply to some of the questions. MNKay... crazy setup, but I wouldn't touch it! Nitro is fun, but decent electric parts can match it for performance and be much more reliable. I can see how that tranny would be problematic. Mine is tough enough to line up well wit a flexible belt, never mind trying to align and mesh gears and a vibrating .12. That said, nice job thinking outside the box. In terms of my gearing, I run a 12 tooth pinion into my gear box, which yield a lowering ratio of 3.8:1. The belt pinion pulley is 16 teeth, the spur pulley 39. After my original post I made some other modifications. I reinforced the motor mount and tunnel with angled brackets. I also installed some bearings to better support the drive axle. I bought two oil filled shocks for a Duratrax Evader ST. I removed all the plastic links that restricted rear suspension travel, and it works great now. I rewired my motor, ESC, and everything else with Deans Ultra plugs, and bought 2 GP3300 batteries. With the GPs, the LRP runner reverse plus, and the 16 turn Trinity Speedworks, the power is close to being to much for the transmission setup. I snapped my original belt (it had been pretty well abused), and now have a hard time keeping the spur gear assemble tight on the drive axel. Under heavy load it likes to spin and slide away from the tunnel. When that happens, the assemble starts hitting the belly pan and shreds the plastic pretty good. No big deal, but something I'm working on for next year. What I really want to find is a better way to mount the spur pulley to the drive axle. The spur pinion is very well supported, but the spur pulley is so-so, especially under the power I'm giving it. I was thinking about maybe taking the drive exle to a machine shop and having a pully mount made. We'll see what I think up. Overall, this sled is fun as hell to drive. It goes well in a couple inches of snow. It's best suited for flat areas, but it will climb a bit if the snow is packed and it has some speed. It jumps great as long as you hit the jump straight and are prepared to steer into the lean as it comes down. Keeping it upright is a skill that you aquire once you get used to predicting it's movement. For the most part though, it works great, and people love it. It's pretty damn cool!
_____________________________
Kevin
