Tigger N. Bennie
The freaking stock pinion gear slipped when I tried to get on the buggy, then I stripped out the pinion when I tried to tighten it down some more. However, I just finished making a sleeve for the shaft and for the few bleeps I gave it, the pinion stayed on. For how long, that is the unanswered question and next test. I also changed out the shock springs so they are a little softer now. Edit: Well it appears I messed up the brushless motor when I made the sleeve and stuck on the stock pinion. However, the Mini-Inferno is not deadlined since I've already replaced the motor with another Mamba Competition X Package 8000kv motor. This time I stuck a Trinity Mini-T Hi-Speed Metal Pinon gear on it. I also shimmed the transmission using Mugen Seiki o-rings, greased it with some Team Associated Silicone Grease, and ended up replacing another part that was lost in the overall and later found with another Losi Mini-T part. I guess my Kyosho Mini-Inferno is a jack-of-all-trades now with Castle Creations, Mugen Seiki, Team Trinity, Team Associated, and Team Losi parts. I might as well add some Megatech lights (instead of Kyosho Mini-Z LEDs).
< Message edited by Tigger N. Bennie -- 4/12/2005 7:36:35 AM >
_____________________________
Lots of RCs, two cats, and a Nikon.
