Fuel Dinosaur
GA, USA Status: offline
Nitromethane is chemically stable for years when sealed and kept in brown bottles or cans in the dark at room temperature. The fact that it is clear is a good sign. Improperly stored nitro and some cheapo nitromethane from the orient is yellow, or at least has a distinct yellow tinge or even orange. Go ahead and use your nitro and enjoy the power. Store it in the dark and do NOT let the vessel it is stored in heat up in storage or you could get a most unpleasant surprise. PS In my bag of degrees, I have one BS (chemistry) and doctorate major in biolchemistry and advanced organic chemistry, including advanced oraganic, synthesis, advanced inorganic, physical chemistry, instrumental anaylysis, etc. Have also mixed fuels for over 40 years now. Hope this information helps. Major impurities in nitro are the nitroethanes and nitropropane and a few other things, virtually all of which are flammable anyway. Despite all the incredible hype about nitromethane, Angus Chemicals, now a subsidiary of Dow Chemical Co. since about June of 2000 is the ONLY major manufacturer of nitromethane in this hemisphere. Also, Angus makes just ONE grade of nitromethane, about 98.4% pure and it is used for industrial use, car racing, and a very small amount, relatively speaking, for model use. You can select lots of higher purity, usually not necessary above about 99% or so. If you are crafty and can fool most of the people most of the time in your advertising, you can buy cheap Chinese nitro and redistill it, IF you can find industrial chemists stupid enough to do that totally unnecessary and DANGEROUS distillation. Angus distills off the nitro fraction with other compounds to minimize the danger of handling nitromethane, and they do NOT recommend further purification of the nitromethane on a large scale. Despite the hype, it is just far to dangerous. From a chemistry type who still has all ten fingers and 10 toes and BOTH eyes.
