racemiata
Joined: 7/19/2004 From: Vancouver, BC, CANADA Status: offline
EDP50XC is NOT a direct bolt-on for the esky honey bee. I just strapped the motor to the original geared housing like this: Aerohawk, I don't know why the conversion won't provide enough power for your heli. It provides more than enough power for me. The motor is only mild warm after 15-min of continous head-holding hover. Check out my video here. Don't know how your ESC works.To increase tail motor power, I increase "proportional" trim instead of "gyro" gain. And most importantly, make sure the blade is installed such that air is sucked in on the rough side of the blade and blow off the smooth side of the blade. If installed the other way, you get big noise and low thrust.
