ep124
Joined: 9/12/2003 From: ontario, NY, USA Status: offline
Ok, here's the run down. I have a Creek Hobbies Giles 202 think a 160 FX in it. The plane weighs in at about 11.2 lbs. The problem I'm having is that the plans is hovering at near full throttle, maybe 90%, about 3 clicks from full, and pull out needless to say is very week. I've checked out every thing that i could think of, the carb goes full open at full stick, I don't have any expo in it that would mess with it, ect. here's the set up... 11.2 lbs giles 160 FX 18 X 6 zinger (not pro zinger) stock muffler 10% power master and it's tackin at about 8,100 RPM on a good day Ok so i put 8,100 rpm with a zinger prop into a thrust calc. i got and it said i should be pullin about 19.5 lbs. Now if that's true then shouldn't i be hovering at about 60% stick? oh and i forgot to mention that i'm about 400ft above sea level. So do any of you guys kno wut's goin on and how i can get more power out of this motor? any info would be appreciated greatly. Thanx, Eric
