Glue for Balsa to Foam??
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> OMP - Ohio Model Products Support Forum >> Glue for Balsa to Foam?? Page: [1] 2   next >   >>
Login
Glue for Balsa to Foam?? - 10/9/2004 2:56 AM
Sewerdude
Score: 100
Last Login: 11/19/2009
Status: offline
Whats the best glue to use to glue the balsa sheeting onto the foam fuse. I just got a 47" Edge. Does any glue work other than the Gorilla glue? Was wondering if something Titebond would work. I've heard horror stories about usin the poly and the sheeting sliding off the foam if you dont use enough weight. Thanks, JT
< Message edited by JT-Indiana-RCU -- 10/9/2004 2:57 AM >
_____________________________
Every plane has a expiration date!
Hide Signatures
       Post #: 1
RE: Glue for Balsa to Foam?? - 10/9/2004 11:54 AM
STLPilot
Score: 100
Last Login: 12/4/2008
Status: offline
Hopefully well get some good answers from everyone, when we do we'll make this thread a sticky for the forum. We get asked this a lot.
Here At The Wall
Hide Signatures
(in reply to Sewerdude)
       Post #: 2
RE: Glue for Balsa to Foam?? - 10/10/2004 1:17 AM
remcl1
Score: 100
Last Login: 4/10/2009
Status: offline
I used Gorilla Glue on both the GS Edge 540 and the Yak 65 with no problems. I did not use lots of weight. With the two planes I used a sheet of 3/4" plywood to spread out the weight and put two car batteries on it. The Gorilla Glue really does work well and you do not have to be afraid of it. I would hate you see you shy away from it and compromise because you have a miss conception that you have to place a mac truck over it in order to get it to work. I suspect if the sheeting actually slid off then way too much glue was used. Any product will be a headache if not used right.
Hide Signatures
(in reply to STLPilot)
       Post #: 3
RE: Glue for Balsa to Foam?? - 10/11/2004 2:27 AM
RJConnet
Score: 100
Last Login: 11/20/2009
Status: offline
I used 30 minute epoxy thinned with alcohol. Edge glued the sheeting, painted the epoxy on the foam, layed it on the sheeting covered it with a flat board on a flat surface and weighed it down with a tool box full of automotive tools (about 40 pounds) and let it cure. Then painted the other side of the foam and repeated the above. Came out straight as an arrow and is hanging together real well............RJ
Hide Signatures
       Post #: 4
RE: Glue for Balsa to Foam?? - 10/16/2004 10:36 AM
aeroastro
Score: 100
Last Login: 3/1/2007
Status: offline
West Systems 206/105, vacuum bagged, works well. I also laid in some c/f mat at critical stress
points (TE junction) under the balsa.
Peter Young
Watertown MA
Hide Signatures
(in reply to RJConnet)
       Post #: 5
RE: Glue for Balsa to Foam?? - 12/2/2004 2:23 PM
midi0101
Score: 100
Last Login: 6/29/2009
Status: offline
Hi there,
I use just white wood clue......is almost as strong as epoxy, but much lighter
Michael
Hide Signatures
(in reply to aeroastro)
       Post #: 6
RE: Glue for Balsa to Foam?? - 12/3/2004 1:45 PM
AFSalmon
Score: 100
Status: offline
Gorilla glue without hesitation is the preferred method by all OMP folks. This stuff penetrates the wood and foam better than any other glue. We use it on all balsa to foam from the profiles to giant scale planes. Plus it is non-toxic!
By the way we keep plenty of Gorilla glue in stock in various size bottles so if anyone ever needs some with their kit, just say so.
Mike (Salmon) Pilkenton, Chief Slab Designer
Ohio Model Planes
Hide Signatures
(in reply to midi0101)
       Post #: 7
RE: Glue for Balsa to Foam?? - 1/16/2005 10:32 PM
solarviper
Score: 100
Last Login: 10/4/2009
Status: offline
i just built a Giles 202 with foam core wings, i used 100% polyurethane glue, it has unbelievable holding power, and can be bought at home depot or Lowe's..this is also what some manufactures have told me to use
Hide Signatures
(in reply to AFSalmon)
       Post #: 8
RE: Glue for Balsa to Foam?? - 2/17/2005 2:54 AM
Jon B
Score: 100
Last Login: 4/21/2009
Status: offline
I have a 47" edge that I'm getting ready to start on. I want to use polyurethane glue on the fuse like the instructions say, but I don't have any experience using it. How much should I use so that the balsa sheeting doesn't slide off? The instructions say to use 200 lbs. of weight hold the sheeting in place. Is that realy necessary?
Thanks!
Hide Signatures
(in reply to solarviper)
       Post #: 9
RE: Glue for Balsa to Foam?? - 2/17/2005 3:46 AM
Woody218-RCU
Score: 110
Last Login: 11/21/2009
Status: offline
You want a LIGHT film of glue, because as it cures, the poly glues expand in volume, this is why you need enough weight to hold it all together. I squeeze out some glue, and use an old playing card to spread the glue across the foam core. You can drill a couple small holes in the sheeting and insert round toothpicks through the holes into the core to prevent it from sliding off the core.
Cut the toothpicks flush with the sheeting before you add the weight.
This stuff isn't as scary as you may have read, but if you're in doubt, find an old piece of foam and a scrap piece of sheeting, and make a test run with it so you're comfortable with the procedure before you do the real thing.
< Message edited by Woody218-RCU -- 2/17/2005 3:47 AM >
AMA #21855 - Pro Bro #1170
Hide Signatures
(in reply to Jon B)
       Post #: 10
RE: Glue for Balsa to Foam?? - 2/17/2005 4:55 PM
Jon B
Score: 100
Status: offline
What about the weight needed to hold the sheeting in place. remcl1 uses two car batteries but the instructions say 200 lbs would be adequate. I would think 200 lbs might deform the foam core.
Hide Signatures
(in reply to Woody218-RCU)
       Post #: 11
RE: Glue for Balsa to Foam?? - 2/17/2005 5:22 PM
Woody218-RCU
Score: 110
Status: offline
You want the weight spread out over the entire surface of the core. When I built my 65" Yak fuse, I used a piece of granite trim off a building, it's 48" long, 20" wide, and it probably weighs close to 300 pounds, but if you think about it, that much weight spread over 200 square inches is only 1.5 pounds/sq. in. That's not anywhere close to the compression load of blue foam. I have made 72" foam core wings with plain old white styrofoam, and used almost 800 pounds of weight on them while the glue cured. The Gorilla glue actually came up through the balsa sheeting, and it forces itself so deep into the foam core you can't believe it!
You need lotsa weight!!
Hide Signatures
(in reply to Jon B)
       Post #: 12
RE: Glue for Balsa to Foam?? - 2/17/2005 6:21 PM
Jon B
Score: 100
Status: offline
Thanks for your input. I'll find some scrap pieces and give it a try.
Jon B.
Hide Signatures
       Post #: 13
RE: Glue for Balsa to Foam?? - 2/25/2005 2:13 PM
J. Fouty
Score: 100
Last Login: 4/14/2005
Status: offline
The poly glues react to water. If it is cold and dry it will take longer to cure and won't expand as much. A very light mist from a spray bottle on the cores will really set the glue off.
Jeff
Hide Signatures
(in reply to Jon B)
       Post #: 14
RE: Glue for Balsa to Foam?? - 2/25/2005 7:05 PM
rkrider
Score: 100
Last Login: 8/2/2009
Status: offline
How would this work ?
Dave Brown Southern's Sorghum
Hide Signatures
       Post #: 15
RE: Glue for Balsa to Foam?? - 2/26/2005 4:34 AM
J. Fouty
Score: 100
Status: offline
I used it a long time ago on some wing cores. It works pretty well for wing skins, but I'm not sure how well it would adhere the balsa skin to the hard points like the lg mounts or motor mounts. It is really easy to use, and actually smells good. It is a kind of latex sugar and water based contact cement, that brushes on like paint.
Hide Signatures
(in reply to rkrider)
       Post #: 16
RE: Glue for Balsa to Foam?? - 3/1/2005 3:10 AM
jlmeyers
Score: 100
Last Login: 8/19/2009
Status: offline
I used 3M spray contact cement on my 80" edge, Yak54 and my small Edge and it holds great. Spray both sides with adhesive and allow it to dry then stick them together. Viola, instant bond. It is important tp allow the glue to dry first though, If you do not the cement will attack the foam.
Hide Signatures
(in reply to J. Fouty)
       Post #: 17
RE: Glue for Balsa to Foam?? - 3/5/2005 4:39 PM
westy1957
Score: 100
Last Login: 3/5/2009
Status: offline
Hello, I write from Italy, and I don't know the Gorilla glue, neither I can buy it......
I ask: is it an Aliphatic Resin Glue ?
Can I use Great Planes Aliphatic Resin Glue to Glue Balsa to Foam?
Thankyou
Ciao
Hide Signatures
(in reply to jlmeyers)
       Post #: 18
RE: Glue for Balsa to Foam?? - 3/7/2005 6:35 PM
AFSalmon
Score: 100
Status: offline
No, Gorilla glue and ProBond brands are polyurethane glues and expand into the pores of the wood and foam when curing. This is what provides the superior bonding. Yes you can use aliphatic glues but I would still weight the cores down to be sure you get as tight a bond between the balsa and foam as possible. Thinned epoxy also works well but with all the above choices just be sure not to use too much.
Ohio Model Planes
Hide Signatures
(in reply to westy1957)
       Post #: 19
RE: Glue for Balsa to Foam?? - 4/6/2005 3:23 AM
gerryw
Score: 100
Last Login: 1/26/2009
Status: offline
Use 2 Gal ziplocks filled with sand for weights works great.
Hide Signatures
       Post #: 20
RE: Glue for Balsa to Foam?? - 4/14/2005 8:05 PM
geebob@brownsphoto
Score: 100
Last Login: 4/21/2005
Status: offline
Hey guys, I'm no expert by far but I did run into a small problem with the Gorilla glue on my "80 edge kit. I got some of the glue in the wire channel and it blocked the channel. If I were to do it again (I'll buy the arf LOL ) but I would put a strip of masking tape over the wire channel before I glued the skins to the cores.
Just one mans opinion I could be wrong
Hide Signatures
(in reply to gerryw)
       Post #: 21
RE: Glue for Balsa to Foam?? - 4/15/2005 1:54 PM
AFSalmon
Score: 100
Status: offline
Hey that's actually a good idea. Thanks for the tip. Also keep in mind these modern urethane glues are really strong and you don't need very much at all. All you need is a very thin layer, wet the apposing side, and make your sandwich. The water helps activate the glue and allows better expansion into the pores. If you use too much glue it will expand into the servo channels.
Ohio Model Planes
Hide Signatures
(in reply to geebob@brownsphoto)
       Post #: 22
RE: Glue for Balsa to Foam?? - 4/23/2005 1:46 PM
Dragondawn
Score: 100
Last Login: 3/12/2007
Status: offline
FWIW, I tried a foaming/expanding polyurethane glue on a balsa/depron fus... unfortunately I didn't spread it out well enough and where it was thickest in the middle of the fus it expanded BIG time! I had sheets of 3/8" glass on top and then 1/2 doz house bricks for weight. When I made the cut-out for the wing I found gaps of ~1/16" where the glue had 'bubbled' Strike One! On my second attempt I used a very thin skim of 30min epoxy
I'm not saying don't use PU glue, just make sure it's a real thin, even layer you're putting on.
(BTW the poly glue I got here in the U.K. is like the thickness & consistancy of silicon sealer and it comes in the same type of industrial tube. If Gorilla is thinner then you'll have an easier time).
HTH,
Steve
Hide Signatures
       Post #: 23
RE: Glue for Balsa to Foam?? - 4/29/2005 5:21 PM
dbruening80
Score: 100
Last Login: 10/21/2009
Status: offline
Something that I've been doing on foam wings when sheeting them is to run a "woodpecker" tool over the core. If I am using PU glue, I don not use the woodpecker as I am concerned the glue may force itself through the tiny holes. Basically the woodpecker creates tiny holes in the foam and forms "rivits" once the glue is cured. Just a thought.
Hide Signatures
(in reply to Dragondawn)
       Post #: 24
RE: Glue for Balsa to Foam?? - 8/25/2005 10:10 PM
southern_touch9
Score: 100
Last Login: 3/2/2008
Status: offline
For holding the wood and foam together its simple...cans of beer. When you get done drinking all 48 then its time to move to the next step
Layne Minor
Hide Signatures
(in reply to dbruening80)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
2.437RCU1
