Old Mach None Wing Info Questions    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> Old Mach None Wing Info Questions
Page: [1]
Login
Old Mach None Wing Info Questions - 10/11/2004 1:18 AM
ep124
Score: 100
Last Login: 11/21/2012
Status: offline
Hey guys,
Here's the scoop, I have an old mach none kit that i got from a guy at a flea market about a year ago. It is missing some wood and the instuckions but i have built a few kits and decided that i would just build it as i went along, like a big puzzle. I did how ever have a sheet that gave a few messurments and a veiw of the plane to work with. It's now to the point were i have to sheet the wing. But i have never sheeted a wing before. So I have a few questions.
1. Does the wing need to be sheeted or can i just put a few extra spars in it and cover it?
2. If I do need to sheet it, what thickness balsa should i use?
3. How would i go about sheeting it?
Thanx for any info,
Eric
< Message edited by ep124 -- 10/11/2004 1:20 AM >
Hide Signatures
       Post #: 1
RE: Old Mach None Wing Info Questions - 10/11/2004 2:04 AM
fritzke
Score: 100
Last Login: 6/18/2013
Status: offline
Eric,
Put the 1/8" spruce spar in the top of the wing and a strip of 1"
3M fiberglass strapping tape on the bottom, tip to tip.
Perhaps cover the spar with the tape too. Cover with low-temp film.
That'll do er!
Dave
Hide Signatures
(in reply to ep124)
       Post #: 2
RE: Old Mach None Wing Info Questions - 10/11/2004 2:37 AM
ep124
Score: 100
Status: offline
Ok! thanx Fritzke! I'll give that a go!
Hide Signatures
(in reply to fritzke)
       Post #: 3
RE: Old Mach None Wing Info Questions - 10/11/2004 5:21 AM
ep124
Score: 100
Status: offline
Actually me and my dad got talkin. I think we are gunna cut out some of the foam and glass the wing. Any thoughts on this?
Hide Signatures
(in reply to ep124)
       Post #: 4
RE: Old Mach None Wing Info Questions - 10/11/2004 5:39 PM
ptulmer
Score: 100
Last Login: 6/19/2011
Status: offline
You will still need a spar. Make sure you use the lightest fiberglass cloth available and be stingy with the epoxy or you'll end up with a boat anchor. It is overkill tho. Dave's method would be the preferred way.
_____________________________
Coming soon to a grass field near you...
Hide Signatures
(in reply to ep124)
       Post #: 5
RE: Old Mach None Wing Info Questions - 10/11/2004 7:16 PM
ep124
Score: 100
Status: offline
Yea i kno that it can end up heave if i'm not careful. I already have the spare in the wing and i am only planing on putin on 1 wrap. maybe 2 if it sames like it needs it. This is only realy to give it alittle strengh and so i can paint the wing, and not cover it. It's kinda wierd but i can glass things fairly well but my covering jobs are just an embarassment.
Hide Signatures
(in reply to ptulmer)
       Post #: 6
RE: Old Mach None Wing Info Questions - 10/12/2004 1:47 AM
fritzke
Score: 100
Status: offline
Well EP124, if you insist, but go EASY on the epoxy.
(Don't even THINK about using polyester resin...)
The cloth should have a matte look when you are putting
it on, and if it looks glossy, you are using too much epoxy.
Use 1/2 to 3/4 oz per sq yard cloth, fill with with thinned Elmers wood filler,
and use just enough paint to make it opaque. That shoud do it.
You could use polyurethane and slikspan too.
Dave
Hide Signatures
(in reply to ep124)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.297RCU1
