Lift
TX, USA Status: offline
Bill, To answer you question specifically the ONLY things that are not "ideal" for full blown 3D on the Hawk III are: 1) The wire drive no matter how well you de-tune your gyro will have some torsional twisting that makes aggressive manuevers such as tic-tocks, piro-flips, continuous flips/rolls more challenging. Notice I didn't say impossible but challenging. All that happens is the tail likes to shake a bit during the load/unload of power in the midst of the manuever. Now, as far as wire drives go the Century system is the absolute best. But, I think that if you get to the point where you are doing true 3D then you should consider the torque tube upgrade. But, for inverted flight/hovering, rolls, loops, flips/tumbles, backwards flight, tailslides, funnels, you can will be fine. 2) Cyclic performance is set tame to begin with. If you run the stock paddles and weights and get into flips/stationary rolls and fine the machine to slow then change these to the MA 3D 3mm paddles. This will wake it up but expect it to be pitchy in FFF with woodies. These paddles will do fine with any of the quality composites out of the market that have some weight to them. In addtion you can modify the mixing ratios by changing some balls on the bell mixers and swash to create a more lively flybar. This gets sticky but if you take the time to understand the head you will come out with more knowledge than most heli flyers and have a sweeeeeeeeeeeet setup!! Hope this helps. The Century helis are very nice. People are just now beginning to realize it!
