murphy
Joined: 12/26/2001 From: Eynon, PA, USA Status: offline
The most used tool on my bench is my Dremel,,,, and the most used bit for it has to be the Zip-Bit!!! It's a 1/8 inch frill bit that bores its own hole, then it's flutes are ground in such a manner that it cuts sideways,,,,, like a rotary jig saw,,,,, gotta love this bit!!! Also it's fantastic for gouging out styrofoam, like for servos, receivers, spars, etc, ( I build Zagis for the LHS, and =would be lost without this tool and bit)!!!!!!
_____________________________
Nothing is as easy as it looks, Everything takes longer that you think it will, and
