RE: TF GS P47 Build - yeah another bloody one!!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AZ Model Aircrafters 1/4 Scale Albatross D.V - RTF
Seller:  Dumb Thumb
Details:   $2,500.00   |  6/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: TF GS P47 Build - yeah another bloody one!!
Page: <<   < prev  373 374 [375] 376 377 378 379 380 381 382   next >   >>
Login
RE: TF GS P47 Build - yeah another bloody one!! - 5/2/2012 10:39 AM
dubs1946
Score: 100
Last Login: 6/18/2013
Status: offline
I had 2 more flights today with my P47 with a 3W85 in and just of of interest i put a fish scale on the tail to check the thrust.
It has a Chinese 26X10 prop and was turning just around 6100 RPM and put out 18KG of thrust on the fish scale and in old money that's near to 40 Pounds of thrust.
The aircraft weighs 35 Pounds dry so a good ratio.
Dave.
Hide Signatures
(in reply to Peter_OZ)
       Post #: 9351
RE: TF GS P47 Build - yeah another bloody one!! - 5/2/2012 12:16 PM
PSJDBF
Score: 105
Last Login: 5/27/2013
Status: offline
Hey Dave long time since we crossed paths, I,ve fitted a GT80 to my Zero and mounted it vertically, made up some exhaust headers & got some flexi exhaust tube so I could have them exiting in a scale location, also did the electronic ignition mod with plug adapters so I could use the CM6 plug/HT boots which allowed me to cowl the engine with out cutting it up.
I,m running a hover 22X10 at 7400 RPM, only two flights done so far & really happy with the engine, no vibration very smooth throttle response & really pulls the Zero through the air.
Loaded a vid on utube of the first flights if you havn't seen it, second flight I opened the GT80 up & she was moving out, alittle deceiving on the vid as theres not a lot in the vid to reference the speed off (alot of flat red dirt out here ), But another guy filmed it on his iphone & you get a better sense of the speed it was doing.
Cheers Steff.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to dubs1946)
       Post #: 9352
RE: TF GS P47 Build - yeah another bloody one!! - 5/3/2012 2:59 AM
Peter_OZ
Score: 108
Status: offline
mate I can relate to the speed element. I have the 21x12 mejink however you spell it and it really unloads coming down hill. I am actually amazed at just how fast it is going when it burns past, have actually started pulling back to 1/2 throttle as I enter the bank so i am not overstressing the airframe or likely to cause a high speed stall.
No idea what static thrust I am getting, have a digital fish scale so would need to hook that up to the tail and measure it. Though I am very happy with 7500 rpm on the ground.
Very happy with the GT-80.
_____________________________
fun police have struck again
Hide Signatures
(in reply to PSJDBF)
       Post #: 9353
RE: TF GS P47 Build - yeah another bloody one!! - 5/3/2012 4:09 AM
dubs1946
Score: 100
Status: offline
Hi Steff and Pete, i must say i love the GT 80.
The 3W works out about $1100 by the time you have bought the overpriced silencer.
The trouble with 3W is everything is overpriced.
I stuffed it in big time when a regulator burnt out on my TA152 and a new crank and rod was needed with Erny's input turned out to be $350.The ignition was quoted at over $200 stupid prices so i bought a Rexell for $60 instead.
Also i have found out that the DLE 55 silencer fits as well.That,s what i have fitted to my Sea Fury
What does the GT80 sell form and who is the seller?
It would be good to have a link to that Video Steff.
Where did you get the headers from on your exhaust and what is the black stuff that is joining the flex pipe and where did you get the flex pipe from.?
Dave.
Hide Signatures
       Post #: 9354
RE: TF GS P47 Build - yeah another bloody one!! - 5/3/2012 4:17 AM
apalsson
Score: 168
Last Login: 6/20/2013
Status: offline
Steff, I like the setup in your Zero and how you oriented the engine
I have the MVVS80cc in mine. Works well with a 3-blade 26x10. These are very nice flying planes!
Planning to swap it out for the 80cc version with a built in starter!
MVVS Australia
MVVS Engines, Mejzlik Props, Accessories.
www.mvvs-australia.com.au
Hide Signatures
       Post #: 9355
RE: TF GS P47 Build - yeah another bloody one!! - 5/3/2012 5:15 AM
Peter_OZ
Score: 108
Status: offline
well at least I now know how to spell Mejzlik!!
Hide Signatures
(in reply to apalsson)
       Post #: 9356
RE: TF GS P47 Build - yeah another bloody one!! - 5/3/2012 5:19 AM
apalsson
Score: 168
Status: offline
quote:
ORIGINAL: Peter_OZ
Good man Pete !
MVVS Australia
Hide Signatures
       Post #: 9357
RE: TF GS P47 Build - yeah another bloody one!! - 5/3/2012 6:56 AM
Peter_OZ
Score: 108
Status: offline
thanks mate. flick me that prop price list when you get a moment? Did that carb get away?
Hide Signatures
       Post #: 9358
RE: TF GS P47 Build - yeah another bloody one!! - 5/3/2012 7:28 AM
PSJDBF
Score: 105
Status: offline
Hey Dave , the flexi pipe was from Christian Traders, the black stuff is a product called rescue tape it is a silicone based tape that is fuel & acid proof & rated to 260 Deg C I have about 1.5 " of header inside the flexi pipe so more of a back up ..first used gasket sealer on the pipe & then the rescue tape as a back up & to help with flex vibration etc.
I made the headers up myself using some aircon fittings from work, at first thought they may restrict the flow a little but are working perfectly.
The vid is a little over the top as I was pretty excited to get this one up, but if you forward to the half way piont you'll catch the second flight. .
Cheers Steff.
http://www.youtube.com/watch?v=l9fvZISYceQ&list=UUQ5irRWxnwwtKDK-oncswKw&index=5&feature=plcp
http://www.christiantraders.com.au/
Hide Signatures
       Post #: 9359
RE: TF GS P47 Build - yeah another bloody one!! - 5/3/2012 8:57 PM
apalsson
Score: 168
Status: offline
quote:
ORIGINAL: Peter_OZ
Carb should be with you by now. Hit the post last Monday
MVVS Australia
Hide Signatures
       Post #: 9360
RE: TF GS P47 Build - yeah another bloody one!! - 5/4/2012 3:45 AM
dubs1946
Score: 100
Status: offline
Him Steff, good fun beginning to the video, plenty of go in that motor and it looks like you nothing fell of.
Congratulations.
Dave.
Hide Signatures
       Post #: 9361
RE: TF GS P47 Build - yeah another bloody one!! - 5/4/2012 6:39 AM
Peter_OZ
Score: 108
Status: offline
thanks Ari
Hide Signatures
       Post #: 9362
RE: TF GS P47 Build - yeah another bloody one!! - 5/5/2012 8:14 AM
Peter_OZ
Score: 108
Status: offline
did some work on the dummy antenna today. Needs a little fine tuning (no pun) and glassing. then have to devise a way to mount it so it is removable.
Click for fullsize
Hide Signatures
       Post #: 9363
RE: TF GS P47 Build - yeah another bloody one!! - 5/5/2012 9:56 AM
apalsson
Score: 168
Status: offline
Great workmanship Pete!
MVVS Australia
Hide Signatures
       Post #: 9364
RE: TF GS P47 Build - yeah another bloody one!! - 5/5/2012 10:36 AM
Peter_OZ
Score: 108
Status: offline
thanks mate. Tis but a twig!
P51D is airwirthy again after fitting a new fuel tank after the last one split. sheesh and that tank was only like 25 years old. c'mon Dubro get your act together hehe
Still working on the gear door for the seafury. Sand back the filler tomorrow, hit it with some paint then refit it.
Hide Signatures
       Post #: 9365
RE: TF GS P47 Build - yeah another bloody one!! - 5/6/2012 9:12 AM
Tseres
Score: 129
Last Login: 6/19/2013
Status: offline
quote:
ORIGINAL: Peter_OZ
Nice looking antenna. Anxious to see how you make it removable.
Old Tom
Hide Signatures
       Post #: 9366
RE: TF GS P47 Build - yeah another bloody one!! - 5/6/2012 10:28 AM
apalsson
Score: 168
Status: offline
quote:
ORIGINAL: Tseres
Hacksaw?
MVVS Australia
Hide Signatures
(in reply to Tseres)
       Post #: 9367
RE: TF GS P47 Build - yeah another bloody one!! - 5/6/2012 2:05 PM
Peter_OZ
Score: 108
Status: offline
no mate it is called a foot! Oopppssss
Hide Signatures
       Post #: 9368
RE: TF GS P47 Build - yeah another bloody one!! - 5/6/2012 3:56 PM
glazier808
Score: 291
Status: offline
You guys use your feet for everything down there....even football isnt football there lol...
"hey, you all just back off! Pete's gett'n something done here!"
Pete,
To make mine removable, I used an 1/8th inch dowel, a carbon fiber tube with 1/8 inner diameter, and a servo screw.
- cut the wood dowel. (this piece goes into your antenna)
- cut the carbon fiber tube a scant(technical term)longer.
- insert carbon fiber tube in fuse where antenna is needed.
- I forgot to say, that you should drill a pilot hole in the end of the dowel for the screw.
- use screw to hold. This hopefully is easy to access. If not you can run the carbon fiber tube through the fuse allowing you to put the securing screw on from the outside.
Casey
Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft
Hide Signatures
       Post #: 9369
RE: TF GS P47 Build - yeah another bloody one!! - 5/6/2012 11:02 PM
Peter_OZ
Score: 108
Status: offline
Casey,
mate you have been hanging around aussies too long. Your sounding like a smart ar se hehehe
My thoghts on mounting it are thus:
- antenna is roughly retangualr at the base
- glue a hard balsa block about 1/2" thick under where the antenna mounts on inside surface of fuz
- then take a piece of thickish (another technical term) brass strip, cut a suitable slot in base of antenna then glue the strip into said slot
- make a corresponding slot in fuz where antenna mounts down into the balsa block but make it a tight fit
- antanna is secure and easily removed
That is my basic desgn, I may tweak that as I go on.
Cheers
Peter
Hide Signatures
(in reply to glazier808)
       Post #: 9370
RE: TF GS P47 Build - yeah another bloody one!! - 5/7/2012 12:03 AM
rt3232
Score: 113
Status: online
Guys
I like both ideas.
But Pete I fhink I would once you have the slot right CA that bugger and re sand or use a machine fils to clean it up, for final fit .
Cheers bob t
Hide Signatures
       Post #: 9371
RE: TF GS P47 Build - yeah another bloody one!! - 5/7/2012 1:08 AM
Peter_OZ
Score: 108
Status: offline
yes mate great idea
Hide Signatures
(in reply to rt3232)
       Post #: 9372
RE: TF GS P47 Build - yeah another bloody one!! - 5/7/2012 1:02 PM
Tseres
Score: 129
Status: offline
quote:
ORIGINAL: Peter_OZ
Casey,
- glue a hard balsa block about 1/2'' thick under where the antenna mounts on inside surface of fuz
Cheers
Peter
That's all fine and dandy. You know Bob want's to see some pictures.
Old Tom
Hide Signatures
       Post #: 9373
RE: TF GS P47 Build - yeah another bloody one!! - 5/7/2012 2:24 PM
glazier808
Score: 291
Status: offline
"mate you have been hanging around aussies too long. Your sounding like a smart ar se hehehe"
From you sir.....
Thats a complement!
Casey
Hide Signatures
       Post #: 9374
RE: TF GS P47 Build - yeah another bloody one!! - 5/7/2012 3:37 PM
PSJDBF
Score: 105
Status: offline
Hey peter had a dead stick on the Gt80 yesterday very scary...Not alot of crap in the filter but because it's a cartridge type enough I guess to snuff out two cylinders.
posted a short vid of it on utube ..the sound you dont want to hear from your 80cc.
Chears Steff.
http://www.youtube.com/watch?v=sy9zck6JHqM&list=UUQ5irRWxnwwtKDK-oncswKw&index=1&feature=plcp
Hide Signatures
       Post #: 9375
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.875RCU1
