RE: TF GS P47 Build - yeah another bloody one!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: TF GS P47 Build - yeah another bloody one!!
Page: <<   < prev  156 157 [158] 159 160 161 162 163 164 165   next >   >>
Login
RE: ... - 4/22/2008 10:30:15 PM
sweetpea01
Status: offline
I'm not sure I'll get any tonight as I don't plan to go home before going to my friends workshop.
But he is moving (and so am I) so I have to bring the plane home in the next 2 days so I'll get some photos shortly.
_____________________________
www.propnuts.org
www.hobbiesxtreme.com
(in reply to michel gravelle)
       Post #: 3926
RE: ... - 4/22/2008 10:40:15 PM
michel gravelle
Status: offline
Hi
Great , till than , I look forword to seeing them
Michel
(in reply to sweetpea01)
       Post #: 3927
RE: ... - 4/23/2008 12:32:21 AM
rt3232
Status: offline
Michel
Sorry I missed your question about spackel it is a lite weight product for filling holes and dings in drywall I get mine from Home Depot,I use a product called DAP come in a 16 fl oz container.
I always dampen the wood befor applying and you don't want much thickness, it sands about like med/balsa, also I use a plastic playing card to spread. I have also used auto body putty (not bondo) its a laquire base mtl, but this is a lot heaver and again you don't want much thickness.
Hope this helps
Cheers Bob t
       Post #: 3928
RE: ... - 4/23/2008 2:52:00 AM
michel gravelle
Status: offline
Hi
Thanks for youre reply Bob . I will look for that product , thanks . one last question.............. does it bond to balsa ?
Many Thanks
Michel
(in reply to rt3232)
       Post #: 3929
RE: ... - 4/23/2008 3:16:39 AM
rt3232
Status: offline
It does thats why you wet/dampen the wood first, opens the grain a bit. I can't tell just whare but back about 20 or so pages there are some pic's both fillers being used.
There is also the same prodect pakgd by RED DEVAL just remember the product weighs less than the container
Bob T
       Post #: 3930
RE: ... - 4/23/2008 3:28:28 AM
michel gravelle
Status: offline
Hi
Right ................ Thanks Bob
Michel
       Post #: 3931
RE: ... - 4/23/2008 4:00:00 AM
Canuck1
Status: offline
My maiden flight is getting very close. Everything is mounted, just waiting for better weather. Too much snow fell the past three days so it may be a couple of weeks out. I want to test run the engine in my garage when it warms up, to double check everything before it flies. I will post more when the initial runs are being conducted.
Nice to see so many P-47 under construction, awsome thread guys.
Craig
Eat, Sleep, Fly
       Post #: 3932
RE: ... - 4/23/2008 7:55:15 AM
sweetpea01
Status: offline
plane and parts are all primed. The days spent sanding where worth it!
I have only a handful of spots to freshen up. We used some marine epoxy primer (its white) The stuff was easy to spray and coated really well. I'll get some photos posted tomorrow.
www.propnuts.org
(in reply to Canuck1)
       Post #: 3933
RE: ... - 4/25/2008 1:35:56 PM
rt3232
Status: offline
Just a little up date, this last wensday figured I could ge my chores done and squirt some primer, but no luck so maybe if it quits raining will get to it this w/e
Bob T
       Post #: 3934
RE: ... - 4/29/2008 1:09:52 PM
rt3232
Status: offline
Finally got the pnl lines painted, and will pull tape tomarrow, will try to post a pic or 2 of what I get. still crummy weather wet, cold and windy
Bob t
       Post #: 3935
RE: ... - 4/29/2008 1:47:38 PM
FliteMetal
Status: online
quote:
ORIGINAL: rt3232 Finally got the pnl lines painted, and will pull tape tomarrow, will try to post a pic or 2 of what I get. still crummy weather wet, cold and windy Bob t
This morning's weather report shows you trying to set records for "late"
spring snow and ice. Cabin fever has to be an ongoing factor in a larger
project to begin with.
Look forward to seeing your panel lines after you sand and peel the tape.
Ed Clayman
http://www.FliteMetal.com
       Post #: 3936
RE: ... - 4/30/2008 4:29:46 AM
rt3232
Status: offline
Hi Ed
You guys are have some crazy weather to. and cabin fever aint so bad beat the wife (in my dreams) kick the dog [)]or just go play in the shop till I can't see straight
Anyway did get some of the tape pulled and from my side of thecamera it looks pretty good for a first try look a little rough as only did enough sanding to pull the tape, hears some pic's see what you think, I konw I am a louesy photografer
Cheers Bob T
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to FliteMetal)
       Post #: 3937
RE: ... - 4/30/2008 7:22:00 AM
SMUGator
