RE: TF GS P47 Build - yeah another bloody one!!
Tower Hobbies
Logged in as Guest
Users viewing this topic: KojakDave
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: TF GS P47 Build - yeah another bloody one!!
Page: <<   < prev  159 160 [161] 162 163 164 165 166 167 168   next >   >>
Login
RE: ... - 5/11/2008 10:41:36 PM
sweetpea01
Status: offline
Ouch.......I laid a bunch of CF cloth in the gear areas to beef it up.
_____________________________
www.propnuts.org
www.hobbiesxtreme.com
(in reply to Peter_OZ)
       Post #: 4001
RE: ... - 5/11/2008 11:30:03 PM
rt3232
Status: offline
Can I add a double ouch
Good luck with the repair
Bob T
(in reply to Canuck1)
       Post #: 4002
RE: ... - 5/12/2008 1:09:55 AM
Peter_OZ
Status: offline
tripple !!!
and a eeek
and a boo hoo too
(in reply to rt3232)
       Post #: 4003
RE: ... - 5/12/2008 3:13:04 AM
easton24
Status: offline
Well I finished painting on my P-47. I ended using the nelson paints with lusterkote for the aluminum. This is my first using air gun and air brush. Lets see if I can get the images on here.[image][/image]
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 4004
RE: ... - 5/12/2008 4:55:47 AM
Canuck1
Status: offline
I feel like a complete dumba** for tearing the gear out. Had another look and it is not as bad as it looks. Repair the gear rails, and it will be good to go. Still feel like crap about the whole thing, but thats all part of it
Craig
Eat, Sleep, Fly
(in reply to easton24)
       Post #: 4005
RE: ... - 5/12/2008 4:57:40 AM
dwr
Status: offline
Craig, thats a bummer about the gear. The mounts in mine have worked well. They are hard maple And I don't remember if the material was in the kit or I used some of my stuff. I had mentioned to you that after at least a hundred landings I heard a little clattering as I taxied back so inspected the gear (way overdue). Found the inboard blocks on both gears broken loose, but the outboard blocks were doing all the work. The gear stayed in place. All the screws were still in place. This area is certainly a weak spot in the design that can use some beefing up. DWR.
       Post #: 4006
RE: ... - 5/12/2008 5:51:03 AM
sweetpea01
Status: offline
quote:
ORIGINAL: easton24
Not bad for your first time. Practice on some cardboard to see if you can get rid of the hard lines on the camo and it will look even better next time.
www.propnuts.org
       Post #: 4007
RE: ... - 5/12/2008 5:07:04 PM
captainron
Status: offline
Craig,
Thanks for the pics. They are really helpful to me as I am just now beginning that phase of constuction. I see some serious glass and reinforcing to be done on mine. I'm not known for my flawless landings. I can usually count on atleast 3 touch an goes on each landing. I was surprised at how much shimming I had to do on the gear mounts to get'em to lock in the retracted position with that big Dubro 5" tire and wheel. I'll post some pics once she gets a little further along.
DANG! I LOVE THIS HOBBY.....................................................................CAPTAIN RON.
       Post #: 4008
RE: ... - 5/12/2008 6:41:24 PM
Canuck1
Status: offline
Now I am thinking of my best options for repair work. I think the main reason the pulled out was from some sideways motion at the time of touchdown.
Any ideas, on my best approach? I know there are several options. The plywood ribs, outboard are good, the hardwood rail seperated. The inboard area is the concern, due to the opening required for the air cylinder.
Send me your ideas, I know there are several techniques that I can use, and I want to make sure this is the only time I do this.
Craig
Eat, Sleep, Fly
(in reply to captainron)
       Post #: 4009
RE: ... - 5/12/2008 7:35:31 PM
Planker07
Status: offline
Craig
Land like Bob and you won't have a problem. Just stay away from the gap in the trees.
Allan
       Post #: 4010
RE: ... - 5/12/2008 7:51:19 PM
Canuck1
Status: offline
Thanks for the tip Al, but that won't help me right now
Hows the jet coming along, and yes I am aware of the gap in the trees, it just jumps out and grabs Warbirds
Eat, Sleep, Fly
(in reply to Planker07)
       Post #: 4011
RE: ... - 5/12/2008 9:57:02 PM
Peter_OZ
Status: offline
Craig,
check your PM mate
cheers
Peter
       Post #: 4012
RE: ... - 5/13/2008 7:27:10 PM
Canuck1
Status: offline
Thanks for the PM Peter.
I am heading out of town for a couple of days, and will be home by the weekend. I will begin the restoration when I return. I dont want to over engineer the mounts, so if it happens again the wing will not be destroyed. But it will not happen again, now I will always be thinking about the gear.
Craig
Eat, Sleep, Fly
       Post #: 4013
RE: ... - 5/13/2008 8:47:50 PM
