RE: TF GS P47 Build - yeah another bloody one!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: TF GS P47 Build - yeah another bloody one!!
Page: <<   < prev  165 166 [167] 168 169 170 171 172 173 174   next >   >>
Login
RE: ... - 6/10/2008 7:22:50 PM
SMUGator
Status: offline
Pete, I'm in the process of testing some things right now for raised surfaces, and tried something last night that I think has some promise. Cut the shape out of construction paper or a grocery bag. Add as many layers as you need to get the depth you want. Laminate the layers together with thin CA and then attach them to the surface by wicking the same. Saturate with CA as needed from the top to harden. Brush the surface with 220 grit. Sands like hardwood.
Give it a try on a test panel and let me know what you think.
Tom
_____________________________
Currently building a 1/6 Scale F4U-1A Corsair (BuNo 17777) and finishing a TF 1/8 Corsair
(in reply to Peter_OZ)
       Post #: 4151
RE: ... - 6/10/2008 7:36:12 PM
ramcfarland
Status: offline
Hi SMUGator use Flite Metal for this and you will never look back- www.flitemetal.com I like your idea though
Richard
Fast Richard
(in reply to SMUGator)
       Post #: 4152
RE: ... - 6/10/2008 8:38:58 PM
frankfearn
Status: offline
Keep up the good work fellows. I just love p47s. I have recently finished and flown my Ziroli 1/7 jug, its just fine. It has now had 16 flights and i cant wait for the next, they are superb flying designs. Ive fell in love with these so much that i have just orederd the 92" version to start this coming winter. I will make a short thread and will often refer to this one due to all the input from everyone.
All the best and i wish you all well,
please see my thread,
http://www.rcuniverse.com/forum/m_6768628/anchors_6768628/mpage_1/key_/anchor/tm.htm#6768628
frank.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to ramcfarland)
       Post #: 4153
RE: ... - 6/10/2008 11:38:48 PM
Canuck1
Status: offline
Great pcs of your P-47
Been plugging away on the dummy engine. I did not do any cylinders, but have added the push rods that still need to be painted. I plan on adding the electrical ring which should add more depth. The prop is also just about done, few more touch ups to go.
Craig
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
(in reply to frankfearn)
       Post #: 4154
RE: ... - 6/11/2008 5:50:19 AM
Peter_OZ
Status: offline
quote:
ORIGINAL: SMUGator
Tom
hmmm worth a shot, I will have a fiddle and let you know.
cheers
Peter
www.petenplanes.com.au
       Post #: 4155
RE: ... - 6/11/2008 5:55:00 AM
SMUGator
Status: offline
Richard mentioned Flitemetal earlier and I do use that a bit. I think this construction paper technique is interesting where you want to build things up a bit more or where you want to have a bit more ability to round the edges as if you were to simulate a rib under a cloth surface. Not too interesting for your jug.
Tom
       Post #: 4156
RE: ... - 6/11/2008 6:12:26 AM
SMUGator
Status: offline
Forgot to ask how Ron's Spitty rehab is going?
Tom
       Post #: 4157
RE: ... - 6/11/2008 6:13:31 AM
Peter_OZ
Status: offline
quote:
ORIGINAL: ramcfarland
Richard
thats not a bad idea but I have rolls of tape nad lots of pink filler ready to go.
       Post #: 4158
RE: ... - 6/11/2008 6:17:37 AM
Peter_OZ
Status: offline
Tom,
any technique is worth pursuing, some work in certain applications, and vice versa.
The other thing to do is to use flexible narrow tape for complex curves, normail width tape for straight edges then use spray filler / primer to build it up. Sands very easily and builds up depth with a few waves of the wrist.
cheers
Peter
       Post #: 4159
RE: ... - 6/11/2008 6:23:32 AM
SMUGator
Status: offline
I get the spray part, but I'm a moron when it comes to "wet work" and would like to use solids wherever possible. I liked how you did your raised panels on the stab. I'll probably tinker with both the red putty and the blue ultracoat stuff I sent you a bit of earlier for those parts. It's really true that when the plane is sheeted and glassed that you are about halfway finished.
Tom
< Message edited by SMUGator -- 6/11/2008 6:24:26 AM >
       Post #: 4160
RE: ... - 6/11/2008 6:27:55 AM
Peter_OZ
Status: offline
quote:
ORIGINAL: SMUGator
Tom
he has got the tail feathers sorted for it, got some internal work done prior to mating the halves. He got sidetracked building a niuport 17 which he has just completed. He is currently in hospital and expected out tomorrow. I have told him he is under strict instructions to get back into the Spitty!!
He has actually done quite a bit of the fiddly work, wing saddle, wing bolt mounts etc, firewall.
       Post #: 4161
RE: ... - 6/11/2008 6:29:03 AM
SMUGator
