Peter_OZ
Joined: 6/5/2002 From: Brisbane, , AUSTRALIA Status: offline
DWR, you do need a bit more clearance on that exaust for sure. Understand perfectly about the noise problem, we have similar issues in this country. Though our club is in an industrial estate with a bloody great 6 lane motorway to one side so noise isn't a concern. Ok you need to get a zenoah 90 degree carby adaptor, it puts the carby @ 90 deg to the engine itself. They are I think an aftermarket item. The other throat is what they call a "power throat" It has the throat itself cut at 45 degress. Think they are aftermarket items ok about your engine revs, 6100 is a bit low for a 22x10, you may want to give it a tweak, new plug and check your high speed mix. It might want a tank or 2 through to get the spiders out of it! ENGINE PROPELLER G26A 16x8 @ 8,700 G231 Heli Adjust pitch of rotor to obtain 9,000–10,000 rpm of the engine at full throttle G26 Marine G231 Marine Diameter=65–75mm Pitch ratio 1.9–1.4mm* G38 Gas 18x10 @ 7,300 G45 Gas 20x10 @ 7,200 G62 Gas 22x10 @ 7,200 GT80 Gas 22x12 @ 7,200 24x10 @ 7,200 So if you can locate the 90 degree carb manifold adaptor it will cure your prob of having it too close to the cowl, which by the way they do not like. I have a friend here who can get the 90 deg adaptor if you can not track one down over the there. I think that would be better for you then the power throat adaptor. cheers PEter
_____________________________
www.petenplanes.com.au
