Peter_OZ
Joined: 6/5/2002 From: Brisbane, , AUSTRALIA Status: online
John, the filler that I use for doing sheeting prior to glassing is a lightweight mirror finish spackle that is ready mixed. Made by Selleys, now you probably do not get Selley's products over there but any hardware store will have ready to use lightweight mirror finish fillers. I have used top coat filler that is used for going over the seams in plaster wall sheets but it does not have enough body. Once I have glassed I then use an automotive filler , forget the name but it is normally a reddish colour. It sands well, has good adhesion and you apply it with a piece of stiff card. I use it mainly for raised access hatches, overlapping panels etc. Lay down a piece of tape then spread this stuff out feathering it as you go outboard. Then sand down ot the tape. Leave a nice raised panel of a realistic thickness. No idea on Ultra coat as I have never used the stuff. Is that a glass resin or is it a paint? For resin I use aircraft grade araldite, 50:50 thinned to a water consitency with metho. Paint waise I just use automotive acrylic laquer mixed from paint samples by a panel beating shop I know of. Ahh engines, here's a can of worms. ZDZ60 should be great I would think. The Fuji I'm not sure of. I have heard a few things to the negative on these engines. do some research and ask people who have them is best. For my money Zenoah is way to go. G-62, simple, sturdy and parts a planety and the price is reasonable. You can get electronic ignitions as well from after maket suppliers. Really smooths them out. cheers Peter
