Andrew
Here are some additional sets, all out of RCM -- name, plan # and pub. date. 1/2A SST #654, 8/76 Lynn S,SST and I have flown these Centerfire, #458, 4/71 Cassutt, #469, 5/71 Little Mulligan, #486, 3/72 Fournier RF-4D, #487, 4/72 powered glider All Star Bipe, #499, 7/72 Javalaero, #527, 5/73 powered glider JU-88, #540, 10/73 Whizard, #547, 1/74 several on the forum have built these Supermarine Sparrow, #576, 11/74 Haf-A-Dussin, #588, 2/75 highwing WW I lookalike Tiger Moth, #592, 3/75 Joy Stick, #594, 4/75 Quickie 200, #603, 6/75 pylon Half A Chaos, #607A, 7/75 Half A Stick, 607B, 7/75 -- I have these plans - stretched Stick with conventional gear Skyrider, #611, 8/75 powered glider Scooter MK .049, #622, 12/75 AJC had this one on the forum Rollin Foam, #632, 3/76 Shrike Commander, #640, 5/76 twin P-51D Mustang, #645, 6/76 Cannonshot, 16", #646, 6/76 Ken Willard Miss Cosmic Wind, 31" pylon, #647, 7/76 Cassutt, 30.5" pylon, #657, 9/76 Peppe LaPeuw, 23" bipe, #663, 10/76 Fireball, 40" C/L lookalike, #666, 11/76 Simitar, 50" powered glider, #669, 12/76 Son of Quaker, 38.5" Old Timer, #670, 12/76 Quickie 100, 24" pylon, #674, 2/77 Twin Scooter, 40" Push-Pull Scooter, #681, 4/77 Half & Half, 34" pylon, #687, 5/77 F4U Corsair, 34.5", #690, 6/77 Schoolyard Special, 35", #693, 7/77 Rearwin Speedster, 38", #710, 12/77 Little Mediator, 36" pylon, #713, 1/78 S-Tee, 36" shoulder wing followup to Q-Tee, #723, 4/78 BackYard Canard, 22", #730, 6/78 RCM Trainer, 37", #735, 8/78 Micro Vagabond, 18", #742, 10/78 1/2A Basic Trainer, 38.5", #748, 12/78 Shockwave, 34.5" pusher, #750, 1/79 1/2A Foam Learjet, 55", #760, 4/79 Sunday Seaplane, 37.5", #763, 5/79 Ken Willard Prairie Canary, 36" parasol, #774, 9/79 Variese, 37" Burt Rutan design, #784, 12/79 Would be a real looker Tu Bee, 29" twin .020, #799, 5/80 Forplay, 40" float plane, #812, 9/80 Sonic Booms, 35" twin boom, #820, 12/80 Fokker D XXI, 36", #829, 3/81 Honker Rocket, 36" jedelsky wing with streamlined fuse, #832, 4/81 Marooney, 41" Mooney lookalike, #835, 5/81 Quickie, 27.5" bipe, #840, 7/81 Slick looking, but probably a more difficult build Shoestring, 37" pylon, #866, 5/82 Small Change, 48" for .15, #873, 9/82 Would be a good scaledown Simple Citabria, 35" Fred Reese design, #926, 11/84 Citabria is AirBatic spelled backwards!! Simple Cub, 35", #946, 8/85 Sweet-P, 43" pylon, #968, 6/86 Bumble Vee, 37" v-tail, #978, 10/86 Sniper, 37.5", #984, 1/87 I have these plans -- scheduled for winter Simple Duster, 35", #986, 2/87 SuperMarine Spiteful, 36", #987, 3/87 Fox 107, 46.5" Old Timer, #1004, 11/87 Sonerai, 29.5" pylon, #1079, 11/90 Skeeter, 32" speed, #1097, 7/91 Razor, 20" speed, #1128, 10/92 Pocket Rocket, 28" Fred Reese, #1130, 11/92 Several have built this TinkerBell, 23" bipe, #1140, 3/93 Balsa Bug, 38" cabin, #1152, 9/93 Simple Cap, 35", #1156, 11/93 Das Splat, 32.5, #1178, 10/94 Winter project, but will modify airfoil Wild Weasel, 24", #1223, 9/96 Squert, 36" speed, #1243, 12/97 Sky-Mite, 36" cabin, #1262, 12/98 P-51, 31", #1288, 10/00 4-F, 36" low wing, #1312, 6/02 Apologies for any errors that may have slipped in. Some of the later designs were electrics that can be converted. the "other" andrew
< Message edited by Andrew -- 10/17/2004 12:22:25 AM >
_____________________________
the "other" andrew I'm not older than dirt, but I can remember when it was patent pending
