Flyboy Dave
CA, USA Status: offline
After you start it, close the needle until the engine is running as fast as it will go. Then open the needle until the engine just begins to slow down a bit. You will hear it. That type of engine is much tighter when new, and will get quite hot, until you get some runs on it. Only run it for a few minutes at a time then let it cool off. If you had a tach, you could richen (slow down) the engine about 3-400 rpms, and it would be plenty rich enough to not overheat. Dave.
_____________________________
An engineer says.... "That won''t work". A mechanic says..."Oh yeah, watch this". "Old Age, and Treachery will overcome youth and skill". Revver Bro #4.
